Old 02-07-2007, 11:38 PM   #1 (permalink)
Default unable to print on a network
hi,
I have 2 PCs(one P4 with WinXP and other P3 with win 98)connected through a LAN and a printer connected to the win98 PC.
I want to share that printer with my other pc too.
But when I try to add the printer add printer wizard just stops responding.
Please tell me how to solve this problem...
Thanks in advance
purujitb is offline
Old 03-07-2007, 01:33 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: unable to print on a network
please answer me these question:
1) wht OS is loaded on other computer
2) Can you share DATA between the two PC
Here is the steps to share printer in a small network.You have mentioned that host computer is win98.
1)Start-->>Settings-->>Printers.
2) In the Printers window, right-click the printer and select Sharing. Fill in the form and click OK.
3)Now go to other PC.Make sure both PC are connected through LAN.And host PC is ON and printer is also attached and is in ON state.
start-->>control panel-->>printer and faxes
4) In printer and faxes windows..right click and select "add printer"
click Next
select "A network printer..." and click Next.
select browse for a printer.
Now you will be shown list of printers connected in network.Select your printer. Thats all.Your printer is ready for sharing.
ravi_9793 is offline
Old 03-07-2007, 09:36 PM   #3 (permalink)
the one with printer has "windows 98" and other has windows xp.
yes I can share the data.
I have tried the steps you have told but after selecting the printer the add printer wizard just stops reponding.
purujitb is offline
Old 03-07-2007, 09:48 PM   #4 (permalink)
Beware of the innocent
ilugd's Avatar
something is wrong with your installation. Is your copy of windows xp legimate?
Life is too short. Have fun.
ilugd is offline
Old 04-07-2007, 12:14 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Also check your system firewall setting..and make sure printer sharing is turned ON.
Unable to print. Help!! Urgent!! The Unknown Open Source 7 15-05-2007 08:54 AM
How 2 add print botton on a from in VB Tushar.bar QnA (read only) 1 11-05-2007 10:41 PM
how to print to file anilvc31 Software Q&A 2 07-10-2006 01:41 PM
Print Command prabodh QnA (read only) 1 17-02-2006 05:24 PM
Unable to print from IE 6 Ricky QnA (read only) 1 21-11-2004 03:39 PM
