hi i have a 915 gav intel orignal motherboard, i have 2*256=512mb ram.
i have 4 sokects for ram in which 2 are occupied by 2 strips of 256 mb ram each.
i am planning to buy 1gb more of ram. but i was told by a vendor that if i put 1gb single strip ram then it will not work.
he said ram's are always used in double like 2 strips of 256 = 512 or 2 strips of 512=1gb.
now i plan to add more ram in the future and i only have 2 empty slots, so i was thinking of buying 1 strip of 1gb now, and 1gb later on.
but now i have to buy 2 strips of 512 to make 1 gb.this will occupy my all 4 slots.and so i won't be able to add more ram later on.
is it true that ram's are used in double like he says??
and also the prices i found are 2500/- for hynix and 3000/- for transcend 1gb ddr1 ram.are these prices allright????
also i have heard that hynix rams are often duplicate and not reliiable, also it comes loose whereas transcend comes packed.
which one should i buy??
