Old 02-07-2007, 04:39 PM   #1 (permalink)
Question PC 'turn on ' automatically .
whenever I am turning on my UPS , my PC gets started . Yes I am havent touched any cabinet buttons still . but just turning on my UPS to start it . but after that its got problem . PC starting but without any beep sound . and then nothing is on the monitor and its get blinking . I am very amazed why its getting strted without even trun on button pressing and then gets blank . nothing on the monitor . I cannot use my PC anymore . please help .
reddragon is offline
Old 02-07-2007, 04:46 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: PC 'turn on ' automatically .
Either ur power supply is damaged or its a case of faulty RAM.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-07-2007, 05:20 PM   #3 (permalink)
but my APC ups is fairly new so atleast probability of damaged power supply is less , well what about faulty RAm how to check that . listen while on I am not getting any beep sound while I am pressing UPS again to turn it off , it is making a beep sound .
Old 02-07-2007, 05:24 PM   #4 (permalink)
Stay Silent!
enticer86's Avatar
seems faulty power supply
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 02-07-2007, 08:16 PM   #5 (permalink)
The Devil
blackpearl's Avatar
One of my friends has this exact problem. Its either the power supply or the motherboard. Remember, the power supply connects to the mobo and the the mobo powers the PC ON. If the PC turns on by itself, its eitgher got to be the mobo or the power supply.
blackpearl is offline
Old 02-07-2007, 09:22 PM   #6 (permalink)
Your SMPS may have a problem - maybe its sending the Start signal to the mobo even before you press any switch. Happens sometimes. If possible, try running your machine with another SMPS. Also, check the power switch of your cabinet - maybe it has got stuck or something like that (thus turning on the pc). If problem still persists, it's the mobo.
"Right Off the Assembly Line" --> Time to Seek & Destroy :lol: :D
abhra is offline
Any software to automatically turn on pc CadCrazy Software Q&A 4 16-06-2007 01:06 PM
how to turn of updates mira000111 QnA (read only) 2 10-08-2005 03:57 PM
Monitor turn-off automatically! reddick QnA (read only) 6 13-04-2005 03:32 PM
