Old 02-07-2007, 01:46 PM   #1 (permalink)
Default SATA or IDE?
Guys,
I have a simple question. I am gonna buy a new hdd this weekend. Should I go for SATA or IDE? What is the performance difference between both? I can see that price difference between both types is very small.
Also I have heard that connecting SATA harddisk is different than IDE one.
Please help!
Regards,
Amit Kale.
amitskale is offline
Old 02-07-2007, 02:01 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: SATA or IDE?
Simply go for SATA. IDE or PATA is old standard. SATA is new Standard. There is a big speed differnce the two
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 02-07-2007, 02:14 PM   #3 (permalink)
Depends on factors like ur mobo having sata ports or not,ur budget,backward system compatibility[if u are gonna roam about with ur hdd in hand to collect data from friends having older pc's then u r in aa situation.I've faced such situations.]But u can always convert it to portable if thats what u need. But if ur sys supports it and u aint gonna use it for data transfer then go for SATA,No PATA.
If you can't beat your computer at chess, try kickboxing.
vutonium is offline
Old 02-07-2007, 03:45 PM   #4 (permalink)
NP : Crysis
xbonez's Avatar
obviously go for sata. ide is out now, sata is the latest. compatability wouldn't be a prob unless u have a very old mobo
xbonez is offline
Old 03-07-2007, 03:26 PM   #5 (permalink)
slugger's Avatar
SATA is d way 2 go.
even if ur mobo does not support SATA natively u can buy a PCI-base SATA card dat will enable u 2 attach SATA hdd 2 ur mobo. IC CHIP has a small piece on this card in their June ed
slugger is offline
Old 03-07-2007, 08:42 PM   #6 (permalink)
@Slugger.
Whats the point in getting a SATA disk on a pc with PCI SATA CARD?
PCI architecture doesnot have DATA bandwidth comparable to onboard sata controller.In PCI the speed is limited to 133mbps.so no point in running it off a addon sata controller.Its useful only in emergencies.
vutonium is offline
Old 05-07-2007, 03:02 PM   #7 (permalink)
Thanks for all the replies! I am gonna build a new pc with core 2 duo processor. Obviously the motherboard would be compatible to this processor.
Now suggest me if I should go for SATA or IDE?
How SATA is connected to motherboard? Is there any cable like ide hdd has or by some other way?
Thanks and Regards,
Amit Kale.
Old 05-07-2007, 03:15 PM   #8 (permalink)
OMG...
With all those replies will u still go fer d IDE???
SAta cables're thinner abt less than a cm wide... 2 mm thick... Separate connector with retention clip holder...
Here...
http://en.wikipedia.org/wiki/Image:SATA_Data_Cable.jpg
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 05-07-2007, 03:27 PM   #9 (permalink)
NP : Crysis
xbonez's Avatar
if u're assembling a new pc, it would be absolutely foolish to go for ide. its on its way to extinction and only those people use it who are forced to. u're assembling a new pc, ur mobo will 100% support sata, so defenitely go for sata
xbonez is offline
Old 06-07-2007, 05:26 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
Are there any IDE to Sata Convertor cable available?
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 06-07-2007, 06:58 AM   #11 (permalink)
slugger's Avatar
Originally Posted by vutonium
@Slugger.
the original post had not mentionde if he was going 2 assemble a new rig or going 4 an upgrade. i had assumed dat d guy was going 4 and upgrade since all d other posts had adivsed him to go 4 sata which wud not be possible 4 him 2 do if he had an old mobo not supporting SATA nativley
also buying a SATA hdd now even if his mobo did not support it natively wud mena dat he cud continue using d same hdd, if the guy decided 2 go in 4 a magor upgrade [dat included chanign d mobo]
check my post above
slugger is offline
Old 06-07-2007, 06:16 PM   #12 (permalink)
Wise Old Crow
blueshift's Avatar
What are the technical speeds of SATA and IDE?
Are SATA hd less expensive than IDE ones?
@slugger, whats the price of such PCI SATA Card?
http://twitter.com/blueshift155
blueshift is offline
Old 06-07-2007, 06:20 PM   #13 (permalink)
Dark Star's Avatar
Pata lega to khaega Chata No Sata even get Sata 2
Btw the Technical Speed of Sata is 1.5 gb/sec and Sata 2 is 3.0 gb/se
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 06-07-2007, 11:55 PM   #14 (permalink)
Wise Old Crow
blueshift's Avatar
I askes about SATA and IDE.
Old 07-07-2007, 10:40 AM   #15 (permalink)
ayush_chh's Avatar
SATA. I bought PATA though due to money issues.....
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 07-07-2007, 12:13 PM   #16 (permalink)
harryneopotter's Avatar
theoritically ide has a data transfer speed of 133MBps...for sata its 150 nd for sata2 its 300 MBps
and price diff is hardly of about 100 bucks
harryneopotter is offline
Old 07-07-2007, 02:03 PM   #17 (permalink)
Wise Old Crow
blueshift's Avatar
^ ok thanks.
Old 07-07-2007, 08:21 PM   #18 (permalink)
slugger's Avatar
u shud get one 4 around 1000 (+-100-200), take one with at least 2 ports [they may try 2 sell u one having only one port 4 d same price], although u could also get one with 4 ports 4 around d same price
slugger is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
How to connect SATA HDD to a mobo w/o SATA port ashnik Hardware Q&A 7 31-03-2006 08:52 PM
wats better Hitachi(SATA) 80gb or Samsung(Sata)80gb ??? King_Niral QnA (read only) 12 14-08-2005 05:11 PM
