Old 01-07-2007, 09:51 PM   #1 (permalink)
harryneopotter's Avatar
Default Invisible DVD RW
Hi guys ... I have Asus M2NPV-VM Mobo and lite on 20x dvdrw and i am facing a little prob ....
I tried the Tutorial for changing the default dialogue boxes in XP, using resource hacker. i modified Shell32.dll, timedate.cpl and msgina.dll. after replacing these files ..when i rebooted my system ..it kept restarting after the Xp boot screen (may be i did something wrong ) . .... after that i reinstalled Xp chosing "repair the previous installation option"...... now windows cant recognize my DVD RW .....i looked in Device manager ...there it shows only 1 optical drive (virtual drive of Alcohol 120%). i tried add new hardware ..but no use ..... now wat shld i do ..... plz dnt tell to reinstall XP .... is there any other way to solve it ??? Plz help ...........
cm on guys .....21 views and still no reply ????? is it that big a problem ???? i have reinstalled Xp again( upgrade) ... and during setup it demanded a file and i inserted the Cd .. and it detected the cd very well at that time ...but after completion ...its again the same story ... and the drive is working perfectly fine in UBUNTU (dual boot) ..... wat shld i do ??? i dnt want to format my drive .......plz help ..
Last edited by harryneopotter; 01-07-2007 at 09:51 PM. Reason: Automerged Doublepost
harryneopotter is offline
Old 01-07-2007, 10:10 PM   #2 (permalink)
Random Username
Default Re: Invisible DVD RW
Did you try a fresh installl of Xp? I mean like formating the partition which contains Xp and then performing a full install. Or maybe you could try installing the drivers on the CD provided with your DVD drive.
weftr100 is offline
Old 01-07-2007, 10:38 PM   #3 (permalink)
Drivers for optical drive ???? Never heard of them ......... and how do i use the CD which might have come with drive WHEN THE OPTICAL DRIVE IS NOT BEEN DETECTED ....... i knw my first post was a bit lengthy ... but its my main prob that the DRIVE is NOT SHOWING AT ALL ......... wat may be the reason ??
Old 01-07-2007, 10:57 PM   #4 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Go to the device manager... In other devices you might see an unknow device with "!" mark, remove that device driver. Restart the PC. Scan for hardware changes, if u find a hardware, install drivers for it. (You will need original CP disk).
If this not work, I suggest u do a fresh install.
Quiz_Master is offline
Old 01-07-2007, 11:05 PM   #5 (permalink)
clmlbx's Avatar
try doing a fresh install
as u say it is running in ubuntu , so it is software problem
do a fresh install
clmlbx is online now
Old 02-07-2007, 05:43 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
only option is FRESH installation ..........
& try using NORTON GHOST ....... easy 2 install XP within 5 min ..........
ax3 is offline
Old 02-07-2007, 06:41 PM   #7 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
TRY THIS...
go to
RUN>>regedit
>>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Co nt rol\Class\{4D36E965-E325 -11CE-BFC1-08002BE10318}
Delete upper filter and lower filter entries and reboot....
Do backup ur registry before doing this.
wizrulz is offline
Old 02-07-2007, 07:17 PM   #8 (permalink)
^^ already tried but cldnt find UPPER or LOWER entries ........
Old 02-07-2007, 10:02 PM   #9 (permalink)
Select Start->Run, type 'gpedit.msc'. Go to User Configuration->Administrative Templates->Windows Components->Windows Explorer. There are options like hiding specified drives in My Computer & so on. Check those options. If this does not work, try running the "Add New Hardware" wizard from Control Panel.
"Right Off the Assembly Line" --> Time to Seek & Destroy :lol: :D
abhra is offline
Old 02-07-2007, 10:17 PM   #10 (permalink)
Learner
Kniwor's Avatar
Have u the IDE bus drivers installed properly, or is it a sata burner?
Kniwor is offline
Old 04-07-2007, 02:17 AM   #11 (permalink)
Is actually a real word..
In that case what shows in device manager, if nothing shows, make sure they are present in BIOS. are they internal drives? other wise yeah listen to the wise old owl (Ax3). I personally won't install anything norton but yeah if you like 'tweaking this' you could restore with the Ghost (save n Restore) option in a few minutes as apposed to hours with CD then drivers then updates, then all the software...
Just a reminder repair only works so that you can backup data, then reload. it is not meant to fix every aspect of windows.
Liggy is offline
Old 04-07-2007, 10:26 AM   #12 (permalink)
device manager is showing nothing .. only 1 cd-dvd drive(virtual drive for alcohol) and no unknown hardware(no question mark). it is showing in BIOS as well as in UBUNTU, but not in xp. and if this a windows prob ... then wats the use of using norton ghost to backup and restore as after restore the files will be same as now .. so the problem will remain same ..............???????
Partition invisible in VISTA pushkaraj Software Q&A 4 21-05-2007 02:32 PM
How to apply invisible mode and detect who is invisible on the forum Arsenal_Gunners Tutorials 82 28-02-2007 11:45 PM
invisible data cyboincomp QnA (read only) 3 03-06-2006 03:54 PM
why can't i run Dues Ex 2 :Invisible War kunwar Gamerz 36 23-04-2005 11:07 PM
Deus ex invisible war ghost QnA (read only) 2 04-01-2005 12:54 AM
