Old 01-07-2007, 11:39 AM   #1 (permalink)
Default hard disk error??
MY old hard disk is not working so i decided to check it by changing it with a new funtioning hard disk.Now the hard disk which was okey before is not functioning...after the POST is complete i get the message in a blue coloured screen saying UNMOUNTABLE BOOT DISK...should i reinstall the OS and try or is there way way aorund it??
thanks
jambay19 is offline
Old 04-07-2007, 02:42 AM   #2 (permalink)
Is actually a real word..
Default Re: hard disk error??
boot to recovery console (you will need XP disk) press R to start the recovery console. select the OS more then likely number 1. at command prompt type fixboot, then fix mbr, then exit and restart the machine
Liggy is offline
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Windows cannot find "rose.exe" error, when accessing Hard disk drives ! vishesh8 Software Q&A 14 11-01-2007 10:01 PM
Hard Disk Error...asks to format IG QnA (read only) 8 23-12-2004 03:43 AM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
