Old 01-07-2007, 10:20 AM   #1 (permalink)
Back in Power
almighty's Avatar
Default how to defrag ?
hi pals
i am not able to defrag my c drive
when i try to defrag it show the drive is not able to defrag below i am pasting the list of errior which i get during defrag
i tried system mechanic to defrag but system mechanic show that dere may b sum damage in drive
how can i fix it
i also runned chkdsk of 5 steps from C:/property/toolds/error checking/ check now/(with both option selection i.e. auto fix the system error and scan and recovery bad sector)
please help me
is the a dangerous prob
and if yes how to fix it
note: yesterday i formated my pc so and i formated c drive
plz help
what i am getting after
Volume (C
Volume size = 13.97 GB
Cluster size = 4 KB
Used space = 5.91 GB
Free space = 8.06 GB
Percent free space = 57 %
Volume fragmentation
Total fragmentation = 0 %
File fragmentation = 0 %
Free space fragmentation = 0 %
File fragmentation
Total files = 31,835
Average file size = 235 KB
Total fragmented files = 1
Total excess fragments = 29
Average fragments per file = 1.00
Pagefile fragmentation
Pagefile size = 768 MB
Total fragments = 1
Folder fragmentation
Total folders = 2,789
Fragmented folders = 1
Excess folder fragments = 0
Master File Table (MFT) fragmentation
Total MFT size = 35 MB
MFT record count = 34,683
Percent MFT in use = 96 %
Total MFT fragments = 2
Fragments File Size Files that cannot be defragmented
None
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 01-07-2007, 10:24 AM   #2 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default Re: how to defrag ?
Try to use Auslogics Disk Defrag.
JohnephSi is offline
Old 01-07-2007, 08:07 PM   #3 (permalink)
use iobit smart defrag if this don't work then change or repair your hdd.
abhijangda is offline
Old 01-07-2007, 08:09 PM   #4 (permalink)
first of all use hdtune software to check for bad sectors in hard disk or any other problem.
hacktom is offline
Old 01-07-2007, 09:09 PM   #5 (permalink)
Q6600 Underclocked
sourishzzz1234's Avatar
Ya use it i also use it not only it's free but also defragmentation is super fast
Core 2 Quad Q6600 2.4Ghz (OC->2.7Ghz)
Cooler Master Hyper 212 Plus
aBIT IP-35 E
1*2GB DDR2 800MHz Zion RAM
320GB Seagate Baraccuda
Sparkle nVdia GeForce 9400GT 512MB
sourishzzz1234 is offline
Old 03-07-2007, 12:37 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Auslogics Disk Defrag ........ is the best ....... fast & error free .........
ax3 is offline
i want to defrag..... can i? k_blues24 Mobiles and Tablets 5 06-03-2007 01:43 PM
Defrag nishant_nms QnA (read only) 1 27-09-2006 08:53 AM
defrag help ashfame QnA (read only) 3 05-05-2006 01:42 PM
Hdd Defrag ! ! ! ax3 QnA (read only) 18 12-08-2005 11:38 AM
defrag ???? atul QnA (read only) 18 15-09-2004 04:12 PM
