Old 30-06-2007, 11:20 PM   #1 (permalink)
Question This USB device can perform faster if it is connected to HI SPEED USB 2.0 port HELP
This USB device can perform faster if it is connected to HI SPEED USB 2.0 port.
This is what I get When I connect My Pendrive.
My Intel® Desktop Board D865GVHZ supports USB 2.0(Checked from the website).
I have windows xp service pack 2.
What is the solution.
Sarvothaman is offline
Old 30-06-2007, 11:52 PM   #2 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: This USB device can perform faster if it is connected to HI SPEED USB 2.0 port HE
yes
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 01-07-2007, 12:05 AM   #3 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
Default Re: This USB device can perform faster if it is connected to HI SPEED USB 2.0 port HE
Originally Posted by NIGHTMARE
yes
spynic is offline
Old 01-07-2007, 12:44 AM   #4 (permalink)
KHUBBU's Avatar
Default Re: This USB device can perform faster if it is connected to HI SPEED USB 2.0 port HELP
doesnt matter...go ahead....ur device is working fine.......
try updating the USB Device driver......frm ur mthrbd CD.
Brand new Day!
KHUBBU is offline
Old 01-07-2007, 01:54 AM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
This may help......
http://www.thinkdigit.com/forum/show...91&postcount=2
sam9s is offline
Old 02-07-2007, 08:36 PM   #6 (permalink)
plug ur pen drive to the USB ports mounted at the back of CPU or motherboard instead of plugging it to front usb port or to any extention cable.. it will work fine.........[]
Saurav
Best Possible PC Configuration or Dream PC -
http://www.thinkdigit.com/forum/showthread.php?t=51297
sr_garg is offline
Old 03-07-2007, 06:39 AM   #7 (permalink)
The High 5 Flyer
sam9s's Avatar
n why would that be....????
sam9s is offline
Old 03-07-2007, 09:33 AM   #8 (permalink)
Hells_Fury's Avatar
Because in many of the cabinets, the front USB ports are USB 1.1 ports...
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 03-07-2007, 06:50 PM   #9 (permalink)
either the driver is not updated(less chances) or u hav 2 enable usb2.0 from bios. check it and reply back.
this faq from intel may help u out:-
Why is my USB 2.0 device operating at USB 1.1 speeds?
Each USB port is treated as an independent USB path, and the performance of each USB port is dependent upon the detected USB device(s) within that USB port (point-to-point) device connection. Its performance will be limited to the least capable performance element within that port's connection. For example, if you connect a USB 2.0 high-speed device to a USB 1.1 Hub, which is then connected to a USB port on the motherboard, the USB 2.0 high-speed device will be limited to the performance through that USB 1.1 Hub.
Refer to the device manufacturer of your USB device for specifications and installation requirements. Additional USB design specifications reference information can be found within the Intel Desktop Board D865GVHZ Technical Product Specification (TPS).
Last edited by HEMANTRATURI; 03-07-2007 at 06:50 PM. Reason: Automerged Doublepost
HEMANTRATURI is offline
Old 04-07-2007, 08:23 PM   #10 (permalink)
The High 5 Flyer
sam9s's Avatar
so you are saying that the same motherboard would provide USB 1.1 for front connection and 2.0 for the rear one.........eh!! sounds stupid if u ask me..........
sam9s is offline
Old 05-07-2007, 09:33 AM   #11 (permalink)
Hells_Fury's Avatar
Yep...I know it sounds stupid but thats the way things used to be...The front USB ports are provided by the cabinet manufacturer whereas the ones at the rear are provided along with the mobo itself.
Old 05-07-2007, 09:41 AM   #12 (permalink)
The High 5 Flyer
sam9s's Avatar
Yep...I know it sounds stupid but thats the way things used to be...The front USB ports are provided by the cabinet manufacturer whereas the ones at the rear are provided along with the mobo itself. When USB 2.0 came out, some mobos came with both USB 1.1 and USB 2.0 headers so that compatibility wouldnt be an issue...
Another logic defying thing, whats the point of providing USB 1.1 and 2.0 both when you anyhow can use 1.1 on 2.0 port. USB 2.0 is backward compatible, its just that you won't get 2.0 speed. Which Mobo did that????
sam9s is offline
Old 05-07-2007, 09:46 AM   #13 (permalink)
Hells_Fury's Avatar
Arent the pin configurations different?
Old 05-07-2007, 09:49 AM   #14 (permalink)
dattebayo
anispace's Avatar
no
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 05-07-2007, 09:53 AM   #15 (permalink)
Hells_Fury's Avatar
I got a little confused in my earlier post and said that mobos provide different headers...What i really meant was that even if the mobo supports USB 2.0, nothing can be done if the front USB ports are USB 1.1...Sorry for all the confusion created...Edited my earlier posts...
Hi Speed USB device can Perform Better Prabhagaran Hardware Q&A 3 06-06-2007 09:36 PM
How to download with faster speed on edonkey rakeshishere Tutorials 2 10-07-2006 01:02 AM
Hi-Speed USB Device - Help chaitanya_vmk Peripherals 5 15-02-2006 11:41 AM
can two computers be connected by USB port jagdish18 Peripherals 8 14-12-2005 01:11 PM
