Old 30-06-2007, 03:16 PM   #1 (permalink)
-----ATi-----
nvidia's Avatar
Exclamation New Processor and Mobo for 20k
I need a new processor and a motherboard for 20k
My choice is -
AMD Athlon64 X2 6000+ processor
MSI K9N SLI Platinum motheboard
Pls tell me if this config is good....
nvidia is offline
Old 30-06-2007, 04:31 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: New Processor and Mobo for 20k
If you can spend 20k..than I will suggest you to go for intel C2D.Intel C2D performance is better than AMD X2.And with motherboard go for intel original 975.
ravi_9793 is offline
Old 30-06-2007, 04:45 PM   #3 (permalink)
darklord's Avatar
with a budget of 20k,
all i can think of is E6600 @ 10k and P35 based mobo.No idea how much they cost
darklord is offline
Old 30-06-2007, 05:29 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
C2D 6420(2.14 GHz / 4MB ) around 8K.
I will suggest you E6600--may be around 12K
Old 30-06-2007, 07:19 PM   #5 (permalink)
20k jus for a proccy n mobo is a bit high nowadays, but if u r hell bent upon spending dat much, den i'dd suggest the Intel C2D 6600, with a NVidia 680i.
apacheman is offline
Old 30-06-2007, 08:54 PM   #6 (permalink)
dOm1naTOr's Avatar
A 6000+ performs better than E6600 and outperforms E6700 in some benchmarks. But the price point of 6000+ is much better than the E6700.
With a gud mobo, u can get the maximum out of it. If u have lil[3~4k] more to spend, get the E6700 orelse go for 6000+.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 02-07-2007, 04:44 PM   #7 (permalink)
Phalanx's Avatar
Go for Core 2 Duo... Its way better than anything from AMD... E6600 is an excellent processor which you can get for 10K... The beauty of these processors is that you can easily overclock them to much higher speeds ( and thus performance) with stock cooling... Even without overclocking the performance of this processor is at par if not better than 6000+....
For a mobo u can go for the latest P35 based boards; since they support penryn ( which have not yet been released in the market and offer even grater performance than the present proccys) you only have to change your proccy in your next upgrade.... Am not sure of the prices though....
Else, u can go for the MSI P6N Sli Platinum Motherboard.... Check out the MSI website for its features... U might get penryn support on it too, but dont count on it...There is no official confirmation for the same...U can get one for around 11K... U can also check out the 'non-Platinum' version of it.... It retails for less than 10K...
So an E6600 + P6N Sli will cost you less than 20K....And thats a killer combo...
Hope this helps...
Phalanx is offline
Old 02-07-2007, 06:58 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
choose AMD only if U want to adjust with ur budget.Else C2D is everyones choise.
Old 09-07-2007, 10:09 AM   #9 (permalink)
-----ATi-----
nvidia's Avatar
amd 6000+ is better than e6600 but not as good as e6700.... so i taught tht this was the best i can choose....
nvidia is offline
Old 09-07-2007, 01:35 PM   #10 (permalink)
Buyin c2d's now is kinda weird wen they're gona release d 1333Mhz proccys and lower d rates...
Wait fer d month end... Prices goin down n get a E6550..
Add a XFX 680iLT mobo fer 10k...
Everythin in ur budget..
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 09-07-2007, 01:41 PM   #11 (permalink)
Dark Star's Avatar
Originally Posted by aravind_n20
A 6000+ performs better than E6600 and outperforms E6700 in some benchmarks. But the price point of 6000+ is much better than the E6700..
Rofl I think u are dreaming Btw get E6750 @ 9-10k after 16 July + P35 board
Again a big rofl WHy u all are giving wrong suggestion if u do not what exactly the truth is
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
AMD mobo & processor ruturaj3 Hardware Q&A 4 03-06-2007 12:21 PM
Best Processor And Mobo Under 10k arcticflare Hardware Q&A 12 27-08-2006 02:00 PM
Mobo + Processor digitizen Hardware Q&A 1 29-04-2006 09:40 PM
Which mobo and processor.... jay4u Hardware Q&A 1 09-04-2006 12:21 AM
