Old 29-06-2007, 07:40 PM   #1 (permalink)
Default Rs 2000 for which pen drive ?
I am getting Rs 2000 to buy a pen drive . which pen-drive I should buy ? better if bigger in space .
i am thinking of sandisk or trancend but trancend is too costly i think ? hows some chinese made models ? are they good enough ?
Look I am not looking for any sequirity featues , I will just do some rapid data transfer . so the volume bigger will be more adv for me .
neither I am looking for the sexiest looking drive but smaller is the bertter because I want to have in as a keychain .
I am NOT looking for and mp3 option ....or any lcd option like that .
BUT performance should be good enough . I mean it should be a strong player in doing its primary job ./
pkt3000 is offline
Old 29-06-2007, 07:46 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Rs 2000 for which pen drive ?
For little less than 2000, you should be able to get 4GB (Kingston, Transcend or Sandisk) or 8GB Chinese made. Dont go for Chinese one....they show fake capacity.
I know latest prices for 1GB and 2Gb since they sell mostly.
1GB Imation, Kingston, Sandisk - RS 400
2GB Kingston - Rs 725
But just a suggestion why not get a laptop drive in a external case....if you really need tons of space. A 100GB or 80GB would cost 1000 more though
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 29-06-2007, 08:22 PM   #3 (permalink)
no pendrive will be essential for my case... hdds are somewhat bigger .
pkt3000 is offline
Old 29-06-2007, 08:59 PM   #4 (permalink)
What?
Ihatemyself's Avatar
San disk cruzer micro u3 is the answer buddy
Here is the data
Instead of rate stated by the vendor i am giving u actual test results(benchmarks by eminent sources)
Single file Read - 17.66 MB/s Write- 7.21 MB/s
Multiple file Read -14.22 MB/s Write- 6.24 MB/s
CPU Utilization % (By Everest 2006 Read/Write * 100 ) -14/5
I think this much data is enough to make it the leader in 4GB series
This pen drive is considered best in 1GB series as well
4 gb costs around 1800 rs.so buddy go wid it with ur eyes closed( not literally)
Good that u r not a features freak .....
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
Ihatemyself is offline
Old 11-08-2007, 05:51 AM   #5 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
I went to nehru place(delhi), and the cheapest I could find was a sandisk for 475.
have the prices increased, coz I am thinking of buying a 4gb one.
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 11-08-2007, 06:04 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Just check one model each of Kingston, Transcend and SanDisk 4 GB models and drop the one with the fastest writing rate per second into the shopping cart.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-08-2007, 06:49 AM   #7 (permalink)
Rebooting
Choto Cheeta's Avatar
once again, its out of my knowledge, that people are ready to buy a 4 GB Pen driver for Rs. 2000 for 4 GB Pen drive, but they dont consider the option of Laptop HDD + USB Casing,
80 GB Segate + Techcom USB portable Casing will cost Rs. 2400/- + TAX in Kolkata, thats Exact 2500/-, for which u get a Coool 80 GB Storaghe with USB plug and play...
and here is the size...
So if storage is the only reason one buying, then tell guys, Rs. 1800/- for a 4 GB or Rs. 2500 for a 80 GB ?? which one would be ur choise ??
yes certainly if one plans to run ready boost of Vista or rather keep the Page file in USB device for faster system performance, then Pen drive is the choise but for storage, sorry to sound rude, but really spending Rs. 1800 or 2000 for 4GB where as in Rs. 2500, 80 GB is available, sounds really dumb to me...
Even this guy is selling 160GB + Casing for Rs. 3200 shiped... http://www.thinkdigit.com/forum/show...10&postcount=9
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-08-2007, 07:05 AM   #8 (permalink)
I have a Sandisk Cruser, but I want to warn you before you purchase it of one thing - The Cruser has Avast U3 Edition pre-installed but it is valid for only 2 or 3 months - you have to pay and subscribe to keep the antivirus updated... Also, there is no write-protect lock. So, if you take your presentation file to a seminar and want to upload there, you will be vulnerable to virus attack if the computers there are infected... On the other hand, many other pen drives have the write-protect lock available. Even without the AV protection, they are better purchases (IMHO)...
Arun
sakumar79 is offline
Old 11-08-2007, 02:48 PM   #9 (permalink)
tech mighty
arun_chennai's Avatar
Choto Cheeta.....very good explanation......
arun_chennai is offline
Old 11-08-2007, 05:39 PM   #10 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Well.. if you consider size, go for Pen Drive. Else, go blindly with Choto Cheeta.
amandeep86 is offline
Old 11-08-2007, 06:25 PM   #11 (permalink)
Back in Power
almighty's Avatar
c.cheeta u rok man !!!!!!!!!!
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 11-08-2007, 10:17 PM   #12 (permalink)
Rebooting
Well u can call it a Palm drive and it is small enough to fit in ur Shirt pocket !!!! i did posted the picture of 80GB, the 160 GB is also same size just 1k costly !!! and just like USD Drive its Plug and play !!!
and thanks for the comments guys
rebooting
ChotoCheeta.com
Old 11-08-2007, 10:21 PM   #13 (permalink)
Palm drive..thats a good one
realdan is offline
Old 11-08-2007, 10:23 PM   #14 (permalink)
napster007's Avatar
go for the drive dude
napster007 is offline
Old 11-08-2007, 10:27 PM   #15 (permalink)
Rebooting
Which Drive ??? Pen or Palm
rebooting
ChotoCheeta.com
Old 12-08-2007, 12:07 AM   #16 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Yepp. HDD with USB casing is the best option, but it require much more care then a pen Drive. As pen Drive are smaller handling them is easy whereas Hdd is a little bigger and handling them and saving them from accidentle shocks is kinda hard when travelling.
Still Hdd with Usb connectors is a better way of transferring data.
Quiz_Master is offline
Old 12-08-2007, 12:36 AM   #17 (permalink)
moshel's Avatar
@Choto Cheeta.....are u saying that actually its a laptop HDD with an added casing????.........
where can i get more details for it?
moshel is offline
Old 12-08-2007, 12:39 AM   #18 (permalink)
Rebooting
yes...
What other details do u need ?? can u be more specefic ??
only thing which can cause real damage is really hard shakes while u are writing data one it !!! as the head is in touch with the Disk...
where as when dormant on accessed my one fell from my hands and my shirt pocket many times nothing happend...
rebooting
ChotoCheeta.com
Old 12-08-2007, 03:34 AM   #19 (permalink)
chesss's Avatar
@choto thanks for the info dude. But I ain't buying this for myself.
chesss is offline
Old 12-08-2007, 10:54 AM   #20 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
ne one knows the rates for hdd drives mentioned above in pune?
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 12-08-2007, 12:24 PM   #21 (permalink)
moshel's Avatar
Originally Posted by Choto Cheeta
yes...
I mean, like XP/vista support info, data transfer speeds, USB 1.2 or 2.0?....etc.
moshel is offline
Old 12-08-2007, 12:26 PM   #22 (permalink)
Rebooting
Supports any OS till date, but yes you much keep it in compatible File format, dont expect to work in Windows 98 SE with large NTFS partition...
its USB 2.0, and HDD is SATA-I 5400 RPM !!! so will work in speed of a normal Lappy HDD...
rebooting
ChotoCheeta.com
Old 12-08-2007, 12:28 PM   #23 (permalink)
Host4Cheap.org
External Laptop HDD is a better option
Old 12-08-2007, 12:30 PM   #24 (permalink)
Rebooting
Huh ??
Price of a 80 GB ??
rebooting
ChotoCheeta.com
Old 01-09-2007, 01:08 AM   #25 (permalink)
Forget transcend, kingston and sandisk, get a buffalo instead.
http://www.sumedh.info/articles/buff...ve-review.html
Mojo is offline
Old 02-09-2007, 01:08 PM   #26 (permalink)
The Frozen Nova
casanova's Avatar
Saurav, it would be requiring external power supply, I guess.
www.nerdweed.blogspot.com
casanova is offline
Old 02-09-2007, 01:32 PM   #27 (permalink)
well...i am in Goa but have contacts at Laminton road...can u suggest which is the best place in mumbai...or at laminton road(grant road).... to buy this product....
clifford is offline
Old 02-09-2007, 01:45 PM   #28 (permalink)
shashank4u's Avatar
Yea I ll also prefer the laptop HDD with casing it is the best option these days..if you wanna buy pendrive go for either kingston or transcend .
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 02-09-2007, 01:47 PM   #29 (permalink)
Rebooting
Hey not attending todays Meet in city center Kolkata ?? (i suppose u r from Kolkata too ??)
On Topic,
No Laptop HDDs with Casing will not need External Power... how ever More largers 7200 RPM 3.5" Desktop ones will need external Power hence their Casing will come with a Power adepter
rebooting
ChotoCheeta.com
Old 02-09-2007, 01:48 PM   #30 (permalink)
Google Bot
Pathik's Avatar
try Casette world/ Prime ABGB/ PC Guide
Pathik is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
GPU for AMD within 2000/- dspawar CPU / Motherboards 9 26-12-2004 10:48 PM
