29-06-2007, 11:33 AM
querry on PSU
ive got my new comp configured and its like this
C2D E6420
XFX 650i mobo
XFX 7900GT graphics
2x 1Gb 800 fsb ram
the seagate 250gb hdd
antibiotic cabinet which has 3 cooling fans
what must be the power supply to be used with is system...Pls Suggest a PSU.... It must also have a separate 6 pin connector for the graphics card
29-06-2007, 01:39 PM
Re: querry on PSU
Get a Corsair 620W or a Coolermanter 600W PSU
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
30-06-2007, 01:38 AM
Re: querry on PSU
I want something for under 3k what would be the other alternatives will the zebronics platinum be sufficient...does it have the 6 pin connector...
*bump*
Reason: Automerged Doublepost
02-07-2007, 09:33 AM
Re: querry on PSU
I dont know bout that but i seriously doubt it...
02-07-2007, 10:40 AM
Re: querry on PSU
See Corsair HX 620 >>>>>>>> Cm 600 watt .. Buy corsair if u can
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
02-07-2007, 09:43 PM
Re: querry on PSU
Just saw this thread: want to ask you geeks somethin'. Can today's 24-pin psu be used with an old mobo which needs a 20-pin connector? I need to change my psu: problem is, getting a 20-pin psu today is next to impossible. A fast reply will be very helpful.
"Right Off the Assembly Line" --> Time to Seek & Destroy :lol: :D
02-07-2007, 10:14 PM
Learner
Re: querry on PSU
yeah, it can be used, just forget the 4 pins.
The corsair 620W is much costlier than CM extreme power 600W, Foyr your rig, the CM 600W will be more than enough.
03-07-2007, 08:47 AM
Re: querry on PSU
C2D E6420
XFX 650i mobo
XFX 7900GT graphics
2x 1Gb 800 fsb ram
what must be the power supply to be used with is system...Pls Suggest a PSU....It must also have a separate 6 pin connector for the graphics card
hEY MAN IF U HAVENT BOUGHT THE pc YET WHY DONT U WAIT FOR THE JULY 22ND PRICE DROPS.. U MAY GET A 6750 AT THAT PRICE. its only a month away.
03-07-2007, 09:02 AM
Re: querry on PSU
How?? The 24-pin connector cannot possibly fit in a 20-pin slot! Or do you say that the config is 20+4, where the extra 4 pins can be somehow ignored?
03-07-2007, 09:48 AM
Re: querry on PSU
Yeah the connector is a 20+4 pin connector...
03-07-2007, 11:20 AM
The Devil
Re: querry on PSU
Yes, its 20+4. The extra 4 pins are usually detachable.
03-07-2007, 12:18 PM
Make Way the LORD is Here
Re: querry on PSU
yup zebronics platinum will be enough.
do check out that it has the 6 pin connector u want or not
03-07-2007, 03:42 PM
Learner
Re: querry on PSU
yeah man, all PSU's are 20+4
03-07-2007, 09:20 PM
Re: querry on PSU
Got it  . Any update on the latest prices of CM or Zebronics Platinum?
03-07-2007, 10:29 PM
Re: querry on PSU
Even if the +4 pins are not detachable, you can just plug it in, so that the 4 pin part will jut out of the slot. Similarly, the 20 pin supply can generally be used with 24 pin mobos. I did so with my A8N-E and a good 20 pin PSU for months till I got an Antec 500W. At that time 24 pin PSUs were hard to get.
V.Prem Kumar
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
SATA Querry
ritish |
Software Q&A |
6 |
09-02-2007 07:39 PM |
querry
RAVIPATEL |
QnA (read only) |
1 |
20-11-2005 11:54 AM |
