Old 28-06-2007, 06:15 PM   #1 (permalink)
Default why the disk in not opening
Hi
in one of our computer whenever we double click any of the partitions it is not opening and showing the following message in a pop up small window.
" windows cannot find 'copy.exe'. Make sure you typed the name correctly, and then try again. To search for a file, click the start button, and then click search. "
we are right clicking on any partition and clicking open or explore then it opens.
Please help.
gramesh is offline
Old 28-06-2007, 08:03 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: why the disk in not opening
COPY.EXE cud be a trojan. scan ur pc with a good av like kav follow it up withe a ccleaner wash.
if problem remains post ur hjt logfile here.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 28-06-2007, 09:34 PM   #3 (permalink)
Is actually a real word..
Agree, it sounds like something I had about a month ago, it is more then likely a trojan. I use ewido's online scan, but try scanning with you AV scanner. you could also try smitfraudfix or hijackthis!
Liggy is offline
Old 29-06-2007, 11:41 AM   #4 (permalink)
thanks anandk and Liggy, but online scanning and hjt may be a problem since the pc is in a small town and does not have a internet connection, let me see.
gramesh is offline
Old 29-06-2007, 02:42 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Read point. 3 here:
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-07-2007, 04:30 PM   #6 (permalink)
thansk vista errrrrr vishal gupta.
My friend formatted the partitions causing problem and the problem was solved before I could pass on this info. Thanks again
gramesh is offline
. is not opening CadCrazy Software Q&A 3 11-03-2007 01:33 AM
Nothing is opening !!! destroyme QnA (read only) 19 25-01-2007 01:09 PM
invalid system disk please replace the disk and press any ke montsa007 QnA (read only) 13 06-06-2005 11:16 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
POP UP NOT OPENING deepakchopra85 QnA (read only) 19 14-05-2005 09:36 PM
