Old 28-06-2007, 08:50 AM   #1 (permalink)
Smile PC started but nothing on monitor . please help
until last night my PC was fully OK . problem started this morning .
Its one year old PC , AMD 3000+ 64 bit venice core , 512 ram , MSI rs482 motherboard , zebrinics cabinet and 740N samsung monitor .
This morning when I started , nothing came onto the monitor , its blue light blinking . I open the signal cord and turned up the monitor . It is working , No probs with the monitor because as I have disconnected the signal cord it said connect the signal cord and the blue light was not blinking .
while turning on , fans are running , even the HDD is ok as in the front of the cabinet the red light is on .( zebronics antibiotic cabinet ) .
now what I should do ?
pkt3000 is offline
Old 28-06-2007, 09:00 AM   #2 (permalink)
Default Re: PC started but nothing on monitor . please help
looks like some ram or some cables are facing loose contact...and try running ur pc without the hdd(this had happened in my old pc , but this prob cant possibly come to newer ones..) . and try removing and re-connecting all cables.. it should work . & try a bios refresh as well , if that doesnt help..
sagargv is offline
Old 28-06-2007, 09:22 AM   #3 (permalink)
no I already ckecked the cable , there is no fault .
when I am turning it on, the 3 lEds in my keyboard turning on for 1 time as usual , only nothing in the monitor ....its light only blinking .
is it a BIOS problem ? or a virus? I do use NOD32 . should I change the CMOS battery? while booting I tried to goto the bios so pressed Del but nothing happened .
pkt3000 is offline
Old 28-06-2007, 09:44 AM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
take out the RAM, clean its contacts with a pencil rubber & install it again.
now check & report back.
__
s18000rpm is offline
Old 28-06-2007, 10:24 AM   #5 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
im afraid....give a look here
problem with motherboard
Booting Problem with P4P800-VM
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 28-06-2007, 11:59 AM   #6 (permalink)
[quote=pkt3000]until last night my PC was fully OK . problem started this morning .
this thing happened with my older monitor.it may not be a cabble problem or ram problem.mite be probs in the monitor itself.
i had to send the monitor to the service centre.they got it repaired.
BULLZI is offline
Old 28-06-2007, 12:10 PM   #7 (permalink)
See the video cable it may be faulty
ThinkFree is offline
Old 28-06-2007, 01:32 PM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
same thing happend with my new xfx 650 mobo. got it replaced and now the replaced is working fine.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 28-06-2007, 02:26 PM   #9 (permalink)
troubleshooter
bluepearl's Avatar
do u installed or uninstalled something the last night?
do u hav UPS or spikeguard?
the prob is most probably with RAM or Moniter cable; chek for any broken contacts wher u connect the pin !!
bluepearl is offline
Old 28-06-2007, 05:51 PM   #10 (permalink)
no I didnt install / uninstalled anything last time and I have APC ups . how u can say prob in cable ? I told u the reasons " No probs with the monitor because as I have disconnected the signal cord it said connect the signal cord and the blue light was not blinking . "
well I forget to mention that CD drive is working too..I mean there are lights on LED and tray is working
pkt3000 is offline
Old 28-06-2007, 07:18 PM   #11 (permalink)
ya man . u got problem in mobo or ram mostly . if u disconnect the monitor completely , ur pc shud boot and u shud hear that beep sound on booting and num lock (usually) turns on . u see hdd activity loading ur os. also , hear ur windows ( if u're using it ) , logon sound. .
sagargv is offline
Old 28-06-2007, 09:39 PM   #12 (permalink)
Is actually a real word..
can you boot to BIOS. maybe your CMOS battery is dead and needs to be replaced
Liggy is offline
New IRC channel started The Unknown Chit-Chat 2 16-06-2007 08:19 PM
can to SMPS be started automatically? digiFriend Hardware Q&A 11 21-01-2007 01:44 AM
Getting started with a new PC. anandk Tutorials 6 09-01-2007 09:23 PM
Getting started with Linux for nOObs! rakeshishere Tutorials 3 07-11-2006 10:12 PM
How to delete a thread that you have started? aditya.shevade QnA (read only) 6 07-09-2006 10:58 PM
