Old 28-06-2007, 03:21 AM   #1 (permalink)
NP : Crysis
xbonez's Avatar
Default lan card not working after hibernation / std by
hi,
every time i switch on my comp after having hibernated it or putting it on stand by, my lan card doesn't work until i restart my comp. pls help
i'm usin a PCI Quantum LAN Card
xbonez is offline
Old 28-06-2007, 10:25 AM   #2 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Default Re: lan card not working after hibernation / std by
^^ Yea this happens if you have not installed the drivers which came with the card. Install it and then try. Else try disabling the card before hibernation. This always works with me.
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is offline
Hibernation choudang QnA (read only) 10 15-09-2005 11:44 AM
Hibernation Possible in Linux??? vipul Open Source 7 24-06-2005 01:42 AM
! Hibernation Problem ! jpushkarh QnA (read only) 8 26-05-2005 08:58 AM
Graphic Card not working!!! idisappear QnA (read only) 12 23-04-2005 11:58 PM
AGP card cooling fan not working ... do i face a problem sri_narra QnA (read only) 2 02-12-2004 08:36 AM
