Old 28-06-2007, 12:28 AM   #1 (permalink)
Default 4 GB thumb drive. deleted data appears again :(
hi all
bought a 4 GB MP4 player from ebay.
main purpose was to hear music and at the same time, to use it as a storage device.
i noticed a problem.whenever i try to delete the files inside it . it says "cant delete.... " chk the attached image
http://img292.imageshack.us/my.php?image=01xg6.jpg
i tried virus checking..but i feel its some prob with the drive ..
whenever i delete the data @ some time, when i refresh it .. the data reappears either with the same size or with 0 KB size
donno watz wrong
i cant format becoz many frnds formatted their thumb drives and it showed sizes almost 1/5 th of the original value (like for a 1 GB drive it showed 128 mb after formatting )
i hav heard taht some mp3 players comes with format software
if anyone can upload it , it would be really thankful
or somebody plz suggest a solution to recover from this problem..
arun_p_g is offline
Old 28-06-2007, 12:38 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: 4 GB thumb drive. deleted data appears again :(
Actally this 1 GB mp3 players have 128/256 MB memory only.
If you format, the player will die.
So, try this. After clicking delete, if it doesn't delete. goto to task manager. Shutdown explorer and restart it again by typing explorer at the new tasks prompt. Delete again.
Nokia N86 8MP
Lucky_star is online now
Old 28-06-2007, 02:37 AM   #3 (permalink)
NP : Crysis
xbonez's Avatar
the sony ns11 series mp3 players and other simlar artificial stuff's capacity drops a lot after fromatting. however, even before formatting the entire space isn't available. u can only avail the space that actually exists on the player, which is what is shown after formatting.
format your player. if space does reduce, simple contact the dealer. he sold u a 4gb mp4 player. anything less means he cheated u
xbonez is offline
Dead usb thumb drive jnpandya Peripherals 6 11-09-2007 09:53 PM
4 GB thumb drive. deleted data appears again :( arun_p_g QnA (read only) 3 30-06-2007 02:14 AM
buying USB thumb drive pkt3000 Hardware Q&A 7 23-06-2007 12:50 PM
Thumb Drive thunderbird.117 QnA (read only) 3 27-09-2005 09:42 AM
USB thumb drive not detecting doulos Peripherals 2 16-02-2005 09:01 PM
