| Forum |
#1 (permalink) |
Drool!...Vista
...what should i do..is the only option left to replace my drive?
Visit my blog http:\\geekgarbage.blogspot.com, but don't click on the ads |
#2 (permalink) |
Laptoping
Funny username. As for your problem, Ejecting the drive using the pin will surely work. Make sure the pin is atleast 2-inch long, give it another try. Since it is a hardware fault, the option from Windows doesn't mean much.
If it is under warranty, you can get it repaired/replaced. Worth trying.
You could think I'm wrong, but that's no reason to stop thinking. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to convert ordinary flash drive into U3 smart drive? | thetopcyborg | QnA (read only) | 13 | 02-11-2008 11:59 PM |
| keyboard shortcut to eject CD in /out as mac does | ranjan2001 | Software Q&A | 10 | 03-03-2007 10:04 PM |
| Eject and Load | Gunner | QnA (read only) | 12 | 07-03-2006 01:47 AM |
| Hard Drive! Optical or Magnetic Based Drive | Stitch | QnA (read only) | 1 | 30-05-2005 11:14 PM |
| Eject Problem...[Sys & HijackThis Logs Attached] | ShekharPalash | QnA (read only) | 5 | 24-04-2005 02:54 AM |
