| Forum |
#1 (permalink) |
The Transcendental
i did some googling and found out that Wacom brand makes the best pen tablets (the graphire and intuos lines) but also the most expensive. I am keen to buy a cheaper variant, preferably 8x6 which uses passive digitizers like the wacom i.e. the stylus should not use a battery. I need it only for inking my ebooks and not for photoshopping. there are several desi makes from Tech-com, Frontech, iBall, Genius. Plz. give me your recommendations and prices if possible. ty
:::::::::: When freedom is outlawed, only outlaws will have freedom :::::::::: |
#2 (permalink) |
I bought front tech for 2700 but that was 5 yrs ago it worked fine for 2 years & developed problem, the pen could not be repaired, so then I got a wacom graphire for 5000/- & the latest price should be around 3500-3700/- for graphire.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. |
#3 (permalink) |
The Transcendental
I'll certainly buy it. u know a good dealer?
browsing the web, i found that graphire-4 [5.5''x4']' costs Rs. 3950. i plan to buy an older version but shall only shell out max 3k. time for a trip.
:::::::::: When freedom is outlawed, only outlaws will have freedom :::::::::: Last edited by ..:: Free Radical ::..; 28-06-2007 at 06:51 AM. |
#4 (permalink) | |
The High 5 Flyer
#5 (permalink) |
The Transcendental
@sam9s.
think of a tablet pc. except you dont scribble on the screen, but on a separate surface. Can be used as a pointing device (mouse) or as an input device to draw on the screen or write using a handwriting recognition software (which have become pretty good btw ). this functionality is more easily achieved in xp tablet pc edition, and higher end flavors of vista. graphic designers use it for photoshop, corporates use it for writing.
#6 (permalink) | ||
Trifen technology ACER showroom bang opp of trifen technology 1st floor. Purple computers 1 st floor near the last end of nehru place market (50mts ahead of computer empire) many other shop have it. 6x8 will be costly around 6-7000 & you don't need that, I got 4x5 size that's the smallest & it works well with my 20 inch monitor, bigger you buy more trouble u will have controlling it, unless u r a painter. IN wacom options u can set the size of the area u want to work within, I have set it to 2x3 inches only. Quote:
Tablet pen is just like a pen & I suffer with RSI using the comp 12-14 hrs a day, I get my arm & index finger numb using the mouse, so the pen helps u doing the same thing as mouse but with extended functionality. Apart from that indeed u can use it for writing signatures, drawing & painting (I do that) & photoshop retouching work. So kids can surely use it & its quite natural for them working with it, it takes a while to get used to it, depending upon the settings u do in the wacom driver available via control panel. Intous is a higher series which is capable of more pressure sensitivity & the graphire is less sensitive, but from experience I can tell u wont make usage of intous until u are a painter. ![]() The above is a newer version & I am not sure if these are available yet in India or not & may be for higher price, the pen & its button are better in this version & the base board has now customizable switches ![]() Hope this helps you decide, more info on wacomsite here. http://www.wacom-asia.com/products/g.../graphire4.php
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 13-07-2007 at 08:58 AM. |
#7 (permalink) | |
The High 5 Flyer
sam9s NAS Project! powered by Unraid! (Corrected!) sam9s HTPC Project! powered by XBMC! sam9s i7 Powered by Sandybridge! My XBMC Collection Last edited by sam9s; 14-07-2007 at 06:46 AM. |
#8 (permalink) |
My plesaure Sam,
my daughter 3ys started scribbling on screen with wacom pen but soon I had to put an end to that she started opening the applications too (tabbing the pen twice will open the program)I later disabled the clicks of the button via control panel & now let here play with her creative scribbling in paint.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| ***what Is A Digitizer???*** | karthik55859 | QnA (read only) | 4 | 28-07-2006 09:03 PM |
| A decent tablet PC... But Which one? | Rollercoaster | QnA (read only) | 2 | 04-09-2005 12:49 AM |
