Old 27-06-2007, 01:42 PM   #1 (permalink)
wwwescape's Avatar
Question No Sound... Right Speaker...
I have an Altec Lansing 2.1 speaker with onboard Realtek AC97 audio...
A month back my speakers stooped working and I had to send it for repairs under warranty...
After it came back my right speaker gave me a bit of problems... On further inspection In realized that there was sound output but it was very faint... On checking with the AvRack cpl, I confirmed no sound from right speaker but output from the left speaker runs through faintly through the right one as well...
I uninstalled and reinstalled the latest drivers and also checked the Sound devices cpl... I checked to see whether thee could be a problem with the onboard sound by using my headset but i found both channels clear...
As a last resort I checked my Altec Lansing speakers on someone else's PC and they worked just fine!!! But they just refuse to work properly on my PC
Please help me!!!
Added:
I also checked my speakers on the front panel on my PC and the left speaker/channel stopped responding...
I again attached the speakers behind my PC and attched my headset to the front panel... Only the right channel worked on my headset and soon as lowered the volume on my headset the speakers right channel started responding...
I also brought in a friends 2 setup speakers... Both speakers work on only one channel at a time either on the front panel or back panel...
What's wrong???
My motherboard is a GA-8I915ME-C with Integrated high quality 6-channel AC'97 audio.
wwwescape is offline
Old 27-06-2007, 10:36 PM   #2 (permalink)
CA50's Avatar
Default Re: No Sound... Right Speaker...
ur sound card might b da culprit. check it out
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 28-06-2007, 11:02 AM   #3 (permalink)
wwwescape's Avatar
Is the onboard sound faulty...
I have heard that if you attach the Line Out jack while the PC is powered on you can damage the onboard sound... Is this true??? Is this what is wrong with my PC???
Old 28-06-2007, 02:37 PM   #4 (permalink)
troubleshooter
bluepearl's Avatar
open up your PC and disable one of the channel either front or back by removing the corresponding cable. Check whether the enabled channel works. If so might be your sound card does not support more than one channels. Because I have the same card and it doesnt support more than one channels.
bluepearl is offline
Help needed in selecting a good sound card - speaker combination saud_khan Hardware Q&A 52 09-09-2007 11:47 PM
Hissing Sound/Disturbance Coming From Speakers/Sound Card ! mikeon Audio 8 15-10-2006 10:37 AM
Speaker Sound Problem ashu888ashu888 Audio 22 11-01-2006 05:01 PM
No sound from right speaker shariq_pj Hardware Q&A 19 07-12-2005 08:25 PM
- by tv6952
- by soumya
