Old 27-06-2007, 12:08 PM   #1 (permalink)
Default Computer Related Problems
HELLO EVERY BODY.
ME KHUSI FROM INDIA.
I HAVE SOME COMPUTER RELATED PROBLEMS
CAN ANY ONE SOLVE MY PROBLEMS
PLEASE E-MAIL ME ON khusi_sharma36@excite.com
khusi_sharma36 is offline
Old 27-06-2007, 12:11 PM   #2 (permalink)
prasad_den's Avatar
Default Re: Computer Related Problems
prasad_den is offline
Old 27-06-2007, 12:56 PM   #3 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Pls post the problem here we are here to try and help you ..
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is offline
Old 27-06-2007, 12:58 PM   #4 (permalink)
UbuntuUser
cynosure's Avatar
LOL. This is one of the funniest post.
Why is she [ ]??
I think shes looking for a technician .
Better take an AMC.
cynosure is offline
Old 27-06-2007, 12:59 PM   #5 (permalink)
Google Bot
Pathik's Avatar
wtf !!
Pathik is offline
Old 27-06-2007, 01:19 PM   #6 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Don't shout with bold captials and write your problem here.
navjotjsingh is offline
Old 27-06-2007, 01:21 PM   #7 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Bhagwan bhi ladkiyo ko smaj nahi saka.....
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 27-06-2007, 01:38 PM   #8 (permalink)
hehehehe
BULLZI is offline
Old 27-06-2007, 10:34 PM   #9 (permalink)
CA50's Avatar
HA HA HA...
plz close the thread as it is of no use
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 29-06-2007, 06:25 PM   #10 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
lol.... y did i evn open this post!
spynic is offline
Old 29-06-2007, 06:32 PM   #11 (permalink)
::cyborg::'s Avatar
Wink Re: Computer Related Problems
wht is ur mobile number khushi? PM me i can solve all ur problems
- KEEP SMILING
::cyborg:: is offline
Old 29-06-2007, 09:07 PM   #12 (permalink)
What?
Ihatemyself's Avatar
Max demon add this thread in ' the most useless threads of digit' and just mention it is the most funny thread.
But khushi since u r new to our forum just read the rules and remember we do not solve problems by personal interactions that is why this is a public forum the reason being if other ppl have same problem like u they can refer to the thread directly without bothering himself(herself fine..) or others ...and dont feel embarassed by the responses above or mine . Itz just this was a very funny thing
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
Ihatemyself is offline
Old 29-06-2007, 09:33 PM   #13 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Username Changed - BlackBerry7100g To BBThumbHealer !
BBThumbHealer is offline
Old 29-06-2007, 09:55 PM   #14 (permalink)
UbuntuUser
cynosure's Avatar
Tum log itna halla macha rahe ho!! abe khushi hai kahan?
This is the height of deewanapan
cynosure is offline
Old 29-06-2007, 10:05 PM   #15 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
ROFLMFAO
rakeshishere is offline
Old 30-06-2007, 12:01 AM   #16 (permalink)
Smile Re: Computer Related Problems
never came across that much difficult problem since past 2 years....
thadhanihemant is offline
Old 30-06-2007, 12:13 AM   #17 (permalink)
>:)I-):(|)8-X
Charan's Avatar
@khusi_sharma36 where are you ... ???
Charan is offline
Old 30-06-2007, 12:18 AM   #18 (permalink)
::cyborg::'s Avatar
are yaar khushi number de de mobile ka
ab bas tarsa mat
- KEEP SMILING
Old 30-06-2007, 06:16 AM   #19 (permalink)
18 Till I Die............
If you have a problem post it in the forum. Members will try to solve it.
mehulved is offline
bunch of problems related to grub vish786 Open Source 5 22-06-2007 09:29 PM
n80 related the.kaushik Mobiles and Tablets 3 10-03-2007 02:35 PM
New graphic card and computer related problems overdose_14 Graphic cards 3 17-05-2006 12:13 PM
related to dos shashanktyagi1 QnA (read only) 8 17-02-2006 03:24 AM
HOT! computer problems help dhawald QnA (read only) 9 04-09-2004 05:45 PM
