| Forum |
#1 (permalink) |
U solved my sound prob. Now i hv got a new one. I hv got two drives( CD-R & DVD-RW) when i insert an autoplatable disc, then the DVD drive autoplays it. But when i rt click on the DVD drive`s icon then i find no "open" command. As a result of this i cannot browse the disc. this prob developed recently. this prob is only with the DVD drive and my CD drive works normal.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW| | Win XP x86 | Win 7 Ult x86 | LinuxMint | | Nokia 2700c | |
#2 (permalink) |
Commander in Chief
Temporarily, you can type in the drive's letters into explorer and access it. Like D:/ .. Wait for a permanent solution from some other member here as am not aware of one.
Harsh J www.harshj.com |
#3 (permalink) | |
Just left click on folders tab in the standar buttons toolbar (the one with back and up buttons.) It will give u an explorer like window on d left just click on d drive once nd it will open up in d right window . OR U can also simply right click on my computer nd select EXPLORE rather dan OPEN . Same kind of window will show up . Hav Fun. No more loosing hair. |
#4 (permalink) | |
>:)I-):(|)8-X
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL |
#5 (permalink) |
Cool as a CUCUMBAR ! ! !
4 hair looss switch 2 VATIKA ........ permanent solution ........ TAAKLA in few days ....... save ur money = barber cost + comb + etc .....
1 problem solved ........ next 1 .......... update ur firmware ......... same thing happened 2 me & problem solved ..... oohh in both cases .... |
#6 (permalink) | |
#8 (permalink) |
yes the drivers r shown in th edevise manager. the drivers r 4m microsoft
#9 (permalink) |
well try removing the dvd writer from the device manager then restart the sytem, n wait till the hardware is installed..
then check whether its working or not.. |
#10 (permalink) |
i tried this but no result
#11 (permalink) |
PlZ HELP ME~~ ITS A CHALLANGE 4 U ALL
#12 (permalink) |
fine...u won the challenge
Enjoy~! alrite jokes apart....wat else listing do u get on rite click....like open with, sharing, copy etc....r they normal? Enjoy~!
No Pain...No Gain Last edited by speedyguy; 12-07-2007 at 12:01 AM. Reason: Automerged Doublepost |
#13 (permalink) |
Bedroom DJ :)
Dear CA50,
Would you please check out the following ? Download "WinXp Manager" and install it. Here you can easily find an option "Click to fix the problem with CD drive" and also check "auto-detect drives during start-up" option. Then reboot . I do hope that your problem might be solved. Waiting eagerly for your feedback... regards. |
#14 (permalink) | |
Thanks pal, plz give the link
#15 (permalink) |
I have never heard about such a problem. My temp. soln. wud be:
Open the command line, type drive letter on the prompt. When u get <drive letter>:\ on the CMD, then type explorer. This shud open win explorer with the DVD drive.
KDE on ArchLinux PHP, MySQL, PostgreSQL, Linux, Apache; Message me to hire (freelancing only) Explore Technology @ http://www.itech7.com Cheap and Reliable VPS Hosting @ http://j.mp/arHk5e |
#16 (permalink) |
well google it....not a big task i guess...newez if u dun wan 2...
http://www.freedownloadscenter.com/U...P_Manager.html Enjoy~!
No Pain...No Gain |
#17 (permalink) |
Wise Old Crow
I think your filetype associations for DVD drive are corrupted. It might be solved by using Registry or
you have to do something in Folder Options>Filetypes. I will check when I am on PC.
http://twitter.com/blueshift155 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| MS Office/Open Office--File Save Dialogue Box-Modify | Varghese | Software Q&A | 1 | 08-04-2006 03:25 PM |
| How do i open .mdf | readermaniax | QnA (read only) | 6 | 09-03-2006 11:53 PM |
