Old 25-06-2007, 02:54 PM   #1 (permalink)
troubleshooter
bluepearl's Avatar
Default Can Not Detect Lexmark Z603
The printer suddenly stopped working last time giving error "printer image not correct"
Tried many uninstalls-reinstalls
Tried driver update
XP is not detecting it only
Anybody?
bluepearl is offline
Old 25-06-2007, 09:31 PM   #2 (permalink)
Is actually a real word..
Default Re: Can Not Detect Lexmark Z603
I'd hate to say this but many problems come when the usb cord is pulled out slightly. try unplugging printer from computer uninstall drivers, reboot reinstall and you should be prompted to plug in the printer. is the spooler service running (either look in task man, or services.msc), when it is installed and you open 'printers & faxes' (control panel) is there a check next to the lexmark?
Liggy is offline
Old 27-06-2007, 06:23 PM   #3 (permalink)
troubleshooter
bluepearl's Avatar
i checked with the cords everything is right
one thing i noticed is that the USB controller is not working properly but on the same USB port A JetFlash pendrive works fine.spooler is running;the printer is not getting detected only !!!
anyways thanx 4 suggestion. Tell me if u can find ny better idea !!
Old 28-06-2007, 12:51 AM   #4 (permalink)
hmm the usb cord for the printer might be damaged then, if you try a different usb port you should get a prompt "found new hardware" if not you may need to buy a new usb cord
Liggy is offline
Old 28-06-2007, 02:28 AM   #5 (permalink)
Help~Is~Here's Avatar
Thumbs down Re: Can Not Detect Lexmark Z603
Dude, if you notice any problems with the USB controllers, then reinstalling the USB/Motherboard drivers is the only answer to it. As far as the pen drive is concerned. It doesnt' require much power from your USB port. Hence problems as such might not affect your pendrive.
Try updating or reinstalling the motherboard USB drivers
Help~Is~Here is offline
Old 28-06-2007, 02:13 PM   #6 (permalink)
troubleshooter
bluepearl's Avatar
its done thanx liggy and help~is~here
ther was some conflict in my modem drivers and USB controller
I uninstalled all the possible drivers and re-installed them back and it worked
Old 28-06-2007, 09:49 PM   #7 (permalink)
No Prob, thats what the forums for. good to see it was resolved fairly quickly.
Liggy is offline
Why your PC can't detect 4GB RAM? blackpearl QnA (read only) 13 23-03-2007 06:24 PM
Lexmark z-13 Installer files... h_kunte Software Q&A 2 22-10-2005 09:11 AM
Lexmark z-13 Installer files h_kunte Hardware Q&A 1 21-10-2005 04:11 PM
dvd rom do not detect dvd ayush QnA (read only) 1 04-10-2004 05:32 PM
