Old 24-06-2007, 05:47 PM   #1 (permalink)
Default ram upgradation suggestion required!!
rite now i hv p5b deluxe supportin max 8 gb ram
i hv now 2*1 gb ram
i wanna hv 2 gb more.
bt in the motherboard book,its written tht "we recommend not 2 use more than 3 gb ram coz the system may show less than 3 gb due to some
addressing mode expansion[somethin like tht,i cant remember rite now]
now my quetion is if i buy a 2 gb ram now,will it be ok??n again if i put a 1 gb ram in a slot and a 2 gb ram in the other slot,will it be total of 3 gb??or even will my machine run properly??
BULLZI is offline
Old 24-06-2007, 06:21 PM   #2 (permalink)
napster007's Avatar
Default Re: ram upgradation suggestion required!!
it wont make any difference if u upgrade more than 2gb of ram no existing processes need that requirement. it is more than sufficient. if u do put an additional 1gb it'll work for sure but u'll be dissapointed.
napster007 is offline
Old 25-06-2007, 12:25 AM   #3 (permalink)
well actually i wanted to know the reason why the system ll show less than 3 gb ram even if i hv more than tht
BULLZI is offline
Old 25-06-2007, 02:32 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Any 32-bit OS can address only upto 3gb RAM so in order to use that 4gb you have to install 64-bit OS. I use winxp pro 64-bit with 4GB ram and it works fine. But remember for gaming or normal usage 2gb is enough.
I work in MAYA so that much RAM is required.
john_the_ultimate is offline
Old 25-06-2007, 10:53 AM   #5 (permalink)
ohh really thnx.
i m goin to hv vista in a couple of days.hope tht ll work fine
BULLZI is offline
Old 25-06-2007, 11:07 AM   #6 (permalink)
No pain....No gain
Originally Posted by BULLZI
ohh really thnx.
Vista runs fine with 2gb ram.
Old 25-06-2007, 11:11 AM   #7 (permalink)
^^^ mr. Bullzi...
Dude dun waste cash..
Its fine with 2 Gb ram...
U wont notice windows boot up in 6 secs flat wen u hav 4 gb ram n all...
2 GB is jus fine...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 25-06-2007, 11:15 AM   #8 (permalink)
@gannu
thnx rather i ll go fer nythin else thts needed.
BULLZI is offline
Old 25-06-2007, 11:40 AM   #9 (permalink)
Stay Silent!
enticer86's Avatar
oh n u can send over the extra ram to me...
ofcourse, free
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 25-06-2007, 11:47 AM   #10 (permalink)
ofcourse, free
Ok sir,plz post ur address.
ram fer free.
delivery charge 2.5k
BULLZI is offline
Upgradation samanvya_ad Hardware Q&A 15 24-05-2007 11:56 AM
Motherboard & CPU Bundle - Suggestion Required sainit Hardware Q&A 2 08-04-2007 11:14 AM
Nokia 5200 - Suggestion Required utsavhanda Buying Advice 16 04-03-2007 09:53 PM
My Old Box Needs Upgradation aku Hardware Q&A 1 13-09-2006 11:12 AM
new pc -suggestion required mukund1224 QnA (read only) 5 23-02-2005 04:39 PM
