Old 24-06-2007, 04:10 PM   #1 (permalink)
antoniobc's Avatar
Smile Upgrade required
No budget as such. Am intending on ugrading just RAM, HDD.
Current Mboard is GA865GME-775
http://www.gigabyte.com.tw/Products/...ProductID=2223
RAM:512 DDR 400Mhz
HDD: IDE 40GB
Processor: Celeron D 3.0Ghz with EM64T
antoniobc is offline
Old 24-06-2007, 06:02 PM   #2 (permalink)
Default Re: Upgrade required
OK so what's the question?
sashijoseph is offline
Old 24-06-2007, 08:19 PM   #3 (permalink)
antoniobc's Avatar
Wanna make it a power house with Linux. Hopefully Open Suse 10.2
However, wont get much juice out of the system with the current config. It wont give me much performance or rather as much as I would like to have.
So I need to upgrade my ram and hdd.
Old 24-06-2007, 11:46 PM   #4 (permalink)
Get nother 512MB fer Dual else d 1Gb...
160Gb HDD... SATA ... Guess d 865 suppoorts sata...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 25-06-2007, 02:09 PM   #5 (permalink)
antoniobc's Avatar
Yeah the 865 supports.Also, my complete problem is as follows.
I have 2 PC's. One is an HP PC without SATA support, 865 chipset mboard, CelD 32bit 2.16Ghz, with 256MB Ram.
Myy other PC is as mentioned above the 64bit CelD.
The question is, should I get a single 1GBstick of DDR or 2 512MB sticks and put the 3rd 512 onto the HP?
Upgrade woo-hoos to Upgrade blues. Help! mightyboosh Hardware Q&A 1 27-11-2006 12:14 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
A little Help required ! superwiz QnA (read only) 11 15-08-2004 01:41 AM
AGP Upgrade Suggestions/Advice Required ChetK QnA (read only) 22 01-08-2004 07:29 PM
