24-06-2007, 11:03 AM
cabbt fans
hi ppl!
just wanted to know whether a fan on top of the cabby helps or not,
an intake fan in the front of the hdds will only help in cooling the hdds rt?
as of now my cabby has 2 fans in the back and 1 in the side pannel.wud it help if i fix a fan on top of the cabby and one in the front?
24-06-2007, 11:16 AM
a_g = JPKN
Re: cabbt fans
the Fan on top will suck in MORE Dust  , so i wouldnt suggest you the top one, but the front intake is good.
ASUS K53SV SX520D + BF3
24-06-2007, 11:29 AM
Re: cabbt fans
the top fan is not for air intake.it'll vent out air from inside the cabby
24-06-2007, 11:30 AM
a_g = JPKN
Re: cabbt fans
not in my Zebronics AntiBiotic  .
dude, you've to get IN as much COOL AIR as you can, so top(or front) has to be intake.
24-06-2007, 11:36 AM
Re: cabbt fans
Its gud to keep an outlet fan at top of the cabby. It worx as a blow hole.
The front intake not only helps in coolin the HDD but also will improve the overall airflow inside the cabby.
Its a gud balance woth 2 intakes[front and side panel] with 2 outlets[top and ob rear].
G3: XPS M1530 |
FZ 16.
24-06-2007, 11:40 AM
Re: cabbt fans
warm air rises up so top fan shud help .......................
24-06-2007, 12:29 PM
Re: cabbt fans
Originally Posted by assasin
hi ppl!
my antec 900 has a 200mm top fan.
yup it sucks out hot air from inside the cabby.
i think unless n until u hv a really hot system,top fan isnt needed.
24-06-2007, 01:58 PM
Re: cabbt fans
^^^ my system aint that hot.its runs pretty cool with max proccy temps of 47-50c under full load and gfx card temps of 72-75 under full load.
24-06-2007, 02:13 PM
Make Way the LORD is Here
Re: cabbt fans
a top fan helps to keep ur system cool though it is only neede if u have a very hot system
24-06-2007, 02:43 PM
Re: cabbt fans
My mobo is getting very hot when playing games around 52-58C. I have 2 side fans which r taking air in and a back fan which is also taking the air in! Coz if i change the direction of the back fan then the blades r obstructed by the metal plate of the cabinet. What to do? Dont have hany place at the front.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
24-06-2007, 05:02 PM
Re: cabbt fans
u ll definitely need at least 1 fan to suck the hot air out of your system.
24-06-2007, 07:28 PM
Re: cabbt fans
Front inlet.
Top outlet/exhaust. (if needed)
Try to get "Vantec Stealth" Series fans if you want minimum noise.
V.Prem Kumar
24-06-2007, 11:20 PM
Re: cabbt fans
The top one can be anythin actually coz tho Antec uses fer xhaust...
Antec uses as Xhaust coz their PSU's are placed in the bottom (like in d P180/P182/P900)
whereas most of dem hav it in d top...
So in Antec's case hot air rises and is sucked out else a back xhaust 120mm fan shud do it....
Vantec Stealths very rare but available @ PRime @ mumbai....
Price's around 600-700...
Likewise Panaflo(frm Panasonic), Sythe(Frm Sony), Delta(Amkes ur OEM stok AMD HSFs), Sanyo-Denki(Stok Intel HSFs)....
Antecs n Cms re jus in... costlier....
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
25-06-2007, 03:02 AM
Re: cabbt fans
I am too planning to buy the Zebronics AntiBiotic cabinet via itwares.
How is the cabinet? How many fans does it ship with?
Cooling good?
Also, am planning to go for 8800 GTS, will a 500 W SMPS be enough(cooler master) or do I have to go for 600W?
Deven
25-06-2007, 09:23 AM
Re: cabbt fans
Antibiotic comes with 3 led fans,1 side fan,1 back and 1 top fan.theres also space at the front of the cabby to install a fan.
a 500w CM psu sud be enough,but get a 600w.
25-06-2007, 11:27 AM
a_g = JPKN
Re: cabbt fans
Cooling good?
its good for 2.4K, but the plastic(front panel) quality is not that good, the CD Tray plastic is kinda flexible. i've used HP Desktop, whose quality is really nice.
temp. remains at 35 degree (b'lore) without the top fan.
if you have people living in your room & you're a Night Gamer/downloader, then try avoiding this cabinet  , lights up the room & you'll get CURSED (a lot)
25-06-2007, 06:27 PM
Re: cabbt fans
Yes, you are correct.
I bought Vantec through ebay.in. got it promptly and the price was in the range you mentioned.
V.Prem Kumar
