Old 22-06-2007, 09:50 PM   #1 (permalink)
harryneopotter's Avatar
Default CRT or LCD ???
Hi guys .. i have to assemble a PC for my aunt who is an Advocate and have to do some reading work on PC(documents) ... so which is the Better option B/w CRT and LCD display so as to minimize the strain. . and which screen size will be better ...15" or 17"(Considering only LCD) .. and if CRT .. then Flat or Not ??? Also if LCD .. then suggest a good model in a strict budget. thnx .. in advance ....
harryneopotter is offline
Old 22-06-2007, 09:58 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: CRT or LCD ???
You should buy a LCD and since she works with Documents....good workspace is what she need.
19inch Widescreen are best these days. Costs around 10800. You can try Benq, AOC and Viewsonice. I personally have BenQ FP92W
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 22-06-2007, 09:58 PM   #3 (permalink)
hey go ffor lcd only i think 17 inch will be appro kkk
hackers2005.3721 is offline
Old 22-06-2007, 10:25 PM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Yeah there are plenty of LCD brands available. They used to say that the LCDs are not good for gaming but for the rest LCDs are the best but now these days LCDs are the also used in gaming because of low response time.
keith_j_snyder2 is offline
Old 22-06-2007, 10:29 PM   #5 (permalink)
thnx for ur replies ...... so it LCD the way to go ..... so wats the best deal in 17" LCD Section ....thnx ...
Old 23-06-2007, 02:35 AM   #6 (permalink)
NP : Crysis
xbonez's Avatar
AOC has some pretty gud deals for lcd mionitors (they even have very high contrast ratio, viewing angle and low response times - if she ever plans to play FEAR )
xbonez is offline
Old 23-06-2007, 03:27 AM   #7 (permalink)
deathvirus_me's Avatar
go for LCD ...
deathvirus_me is offline
Old 23-06-2007, 09:28 PM   #8 (permalink)
i think u €shoudl go for 17 inch but after buying 17 inch of computer i think 19 inch i€s beeter
Old 23-06-2007, 09:38 PM   #9 (permalink)
assasin's Avatar
yeah 19" is better anyday,better still get a 19" widescreen
assasin is offline
