Old 22-06-2007, 07:38 PM   #1 (permalink)
rohus24's Avatar
Default Suggest a c2d
hi guys
plz suggest me a gud c2d proccy
im not a gamer nor do i hve processor demandin apps now
i dont overclock
along with the proccy plz do gimme the price of it in mumbai
thnx
rohus24 is offline
Old 22-06-2007, 08:10 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Suggest a c2d
You can go for Core 2 Duo E4300. Cost is 4850 according to http://www.theitwares.com/processors/processors.htm
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 22-06-2007, 08:26 PM   #3 (permalink)
deathvirus_me's Avatar
Hmmm ... ur not a gamer , u don't wanna oc , and u don't run cpu demanding apps ... then why Intel dude ??? Ur perfect for AMD ... particularly for the Athlon64 X2 4000+ ... runs at 2.1 GHz , has a low TDP ... and runs a hell lot cooler than any C2D on stock cooling ..
deathvirus_me is offline
Old 22-06-2007, 08:45 PM   #4 (permalink)
Ethan_Hunt's Avatar
Have to agree with death on this one.AMD processors & motherboard are best & cheapest combos at the moment.Provide best value for money I would say.Even if you are not too much into gaming then too most of their onboard video controllers are consisting of 6150 chipsets & the newly introduced 690G line up which has good video back up from ATI's stable as well.So if you feel like gaming anytime then this would be a better deal.
V for Vendetta
Ethan_Hunt is offline
Old 22-06-2007, 08:59 PM   #5 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Cool Re: Suggest a c2d
dood if budget is not a problem then the C2D E6600 is a good choice at 14k nehru place price.......else if ur ona splurging spree then go fro the E6700...its really kewl an im also using it......else the E6400 will suffice
Wadadadada!! ??
Ambar is offline
Old 22-06-2007, 09:03 PM   #6 (permalink)
hey i have heard that e4400 is also nice 2.0.
hackers2005.3721 is offline
Old 22-06-2007, 09:56 PM   #7 (permalink)
Host4Cheap.org
E6600 is 10400 now
Old 22-06-2007, 10:28 PM   #8 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Well for non overclockers, AMD is best value for money coupled with any 690 chipset based motherboard.
keith_j_snyder2 is offline
Old 23-06-2007, 12:28 AM   #9 (permalink)
Anindya's Avatar
@Rohus u must give the budget so as to get a better guidance.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 23-06-2007, 12:53 AM   #10 (permalink)
Rebooting
Choto Cheeta's Avatar
as per Over clocking goes, E4300 and the E6420 are the best, and with 4MB L2 and 1066MHz FSB, and a price of Rs. 8k i would say E6420 is the procy for u
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 23-06-2007, 01:37 AM   #11 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: Suggest a c2d
if u want to over clock so go for C2D but i recommend u buy AMD there IMC which not present in INTEL cpu.(In future i am not going to buy any INTEL product )
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 23-06-2007, 02:06 PM   #12 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Originally Posted by keith_j_snyder2
Well for non overclockers, AMD is best value for money coupled with any 690g chipset based motherboard.
i would also suggest amd athlon 64 x2 3600+ to 4200+ whatever suits ur budget
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 23-06-2007, 07:49 PM   #13 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
ya AMD willbe gr8 fr ppl on budget...just get a good mobo wid it like the nvidia 690
Wadadadada!! ??
Ambar is offline
Old 24-06-2007, 02:09 PM   #14 (permalink)
theirs no nvidia 690 its amd 690g
Old 24-06-2007, 03:43 PM   #15 (permalink)
rohus24's Avatar
thnx guys will go for amd
rohus24 is offline
Old 24-06-2007, 03:48 PM   #16 (permalink)
i also think u shoudl go for amd it has nice on board grpaic which will hep u later for manyy other thing
Old 24-06-2007, 03:50 PM   #17 (permalink)
good choice go for amd
Old 24-06-2007, 06:46 PM   #18 (permalink)
AMD Athlon 64 X2 3800+(65W) - Rs 3200
or
AMD Athlon 64 X2 5200 2.6Ghz - Rs 7400 ... Real Bang 4 da Buck !!
apacheman is offline
Suggest the Best!!! Maghi Gamerz 7 20-06-2007 01:19 PM
Suggest me a PDA hailgautam Buying Advice 7 08-05-2007 09:47 AM
Suggest a Web Cam pushprajpradhan Hardware Q&A 3 11-08-2006 09:17 PM
what will you suggest krish Buying Advice 10 04-04-2006 10:54 AM
Please suggest krish Buying Advice 13 15-02-2006 01:39 PM
