Allright this has been buggin for long..I have a limited budget!
i wanted to know whether is it betta goin for E4300 with p5bdlx(clocking)..Can stretch to 6320..but advised not much diff with 6320 n 4300
or Athlon 64 X2 4400+ with M2N-SLI Dlx
dont mind a high end board with a low proccy ..can clock it!
the main idea is keepin the budget of the procy n mobo below 15k with max performance..main usage is programming,movies,gaming,database mana..
if u guys haveany other mobos = to the p5bdlx pls suggests..many advisin abt the xfx!! im so confused!!
E6420 is around 8.2k + TAX in Kolkata, its consider to be one of the best OC C2D at present, compairing with E4300 it comes with 1066 MHz FSB with 4MB L2
XFX 650i is not yet here, but when comes will be bellow 6k + TAX
P5N-E SLi should also come down to 6k range !!!
but with these good Over clocker boards u need to buy a grfx card too...
these are the great board with Nvidia 650i chipset as it will allow you to buy E6420 with Rs. 8200 + TAX compareing with 680i or P5B Dlx of over 10k
for Procy motherboard combo in ur budget best would be a 650i based board like XFX 650i Ultra or P5N-E SLi with e6420
E6420 @ 2.13 / 4MB L2 / 1066MHz is considered to be one of the best over clocker procy, few even consider it better than E6600 or E6700 on OC ground !!! certainly its better than E4300
Hello friends,
This site is a good site for location based pricelists
also Best PC configurations, Branded PC V/s Assebled PC, Dual core PC under 15,000 are interesting pages.
Check this site. www.freewebs.com/abdulmustak/
Buddy i aware of the prices..need the right combination!!!! thx n e ways!!
