Old 21-06-2007, 10:52 PM   #1 (permalink)
RiGhT HeRe RiGhT nOw
ashishnehete's Avatar
Unhappy DVD Writter problem
Guys i need ur help yaar my dvd writter has stoped detecting dvds
i can not access to any of the digit dvds or any other dvd
the firmware is fully updated
its a SAMSUNG writemaster
SH-W162
i really need acess to my dvds PLEASE HELP
ashishnehete is offline
Old 21-06-2007, 11:16 PM   #2 (permalink)
Default Re: DVD Writter problem
Is it gettin detected in d BIOS and Device Manager???
Well, firstly dont u know Samsungs're not gr8 in Optical drives???
1 in a 1000 may not malfunc... Lolz...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 22-06-2007, 12:37 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
clean the lence of ur DVD writer...using lence cleaner.
ravi_9793 is offline
Old 22-06-2007, 10:49 AM   #4 (permalink)
Dude it is getting dettected in the bios and device manager
i brought it quite a time ago
Old 22-06-2007, 11:32 AM   #5 (permalink)
Try cleanin d lens n insert a CD to see if its being read...
Old 22-06-2007, 04:13 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
insert a dvd lens cleaner ........ & try ur luck ........ else RUN 2 the dealer or service center ...........
ax3 is offline
Old 23-06-2007, 10:29 AM   #7 (permalink)
man the lens cleaner is not helping it reads only the dvd lens cleaner data then after that no other dvds is read can u locate some service centers in delhi and mumbai
Old 23-06-2007, 04:23 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
you may find service center...in nehru place.
DVD writter ke sath ? ax3 QnA (read only) 27 27-05-2007 12:06 PM
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
DVD Writter Problem sudhix Hardware Q&A 4 21-01-2007 01:14 AM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
