Old 21-06-2007, 03:23 PM   #1 (permalink)
Hells_Fury's Avatar
Default Cabinets
Could someone suggest a good high-end cabinet...
I was looking at the Antec 900 but the problem is that it will collect too much dust inside since theres a lot of mesh. Same thing with the CM Stacker. I also dont want to go for the Antec P182 cos it doesnt have a side panel.
Are Gigabyte cases available in India?
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 21-06-2007, 07:12 PM   #2 (permalink)
Default Re: Cabinets
Dont think GB has cases in India...
Why dont u go fer the mid-end models such as chieftec or coolermaster cavalier??
I've a cm cavalier w/o dial... Has a side panel n doesn cost a hand n leg... 4k max...
Well, P900 is way too expensive and an investment like dat isn really necessary... Unless u're bulidin d hottest system on earth..(I mean hot in all aspects!!! )
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 22-06-2007, 05:01 PM   #3 (permalink)
Hells_Fury's Avatar
Nah I checked them out but didnt like them. For me 120mm fans are a must and those have a 120mm fan only at the rear of the case. And yes, I am planning on building a really HOT system
Old 22-06-2007, 07:10 PM   #4 (permalink)
^^ the go fer it by all means...
Old 22-06-2007, 09:45 PM   #5 (permalink)
Random Username
Is there any good ATX cabinet for 2K with frontside USB ports? I just want a well ventilated cabinet without any glowing fans or tubelights. Is it safe to use the SMPS included with the cabinet? I'm planning on getting a XFX 8600GT GPU.
weftr100 is offline
Old 22-06-2007, 09:59 PM   #6 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
All Cabinets have front USB and Sound these days. Most come with 450W SMPS too.
Umax and iBall have some nice looking cabinets
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 22-06-2007, 10:37 PM   #7 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Well i also have a Cavalier and i am pretty happy with its performance.Although there is only 1 120mm fan in the back but that do it all!!
If u really need some more cooling then there are many separate fans available from Antec, Cooler Master etc. which u can use because there is a plenty of space into it.
There is also cabinet "Chieftec" well they say its also pretty good & i 've seen it and it was prettier than my Cavalier.
keith_j_snyder2 is offline
Old 23-06-2007, 03:24 PM   #8 (permalink)
Random Username
Thanks, but wiil a 400W SMPS be enough? My config is this:
AMD Athlon 64 X2 4800+, AM2 Socket, Brisbane
ASUS M2N4-SLI Motherboard
Kingston DDR2 1 GB 667 Mhz RAM X 2
Seagate SATA2 250 GB Barracuda 7200 RPM Hard Disk
XFX 8600GT 256MB GPU
Samsung DVD +/- RW Dual Layer
And is it posibble to have two cards in SLI with the PSU that comes with the cabinet?
weftr100 is offline
Old 23-06-2007, 05:58 PM   #9 (permalink)
^^^ Heh u very well know dat wudn be enuf....
Get a powersafe 600W or frm coolermaster....
Dun get the el-cheapo PSU dat comes with the cabby..
Old 23-06-2007, 06:12 PM   #10 (permalink)
Random Username
OK, how about without SLI? Would the el-cheapo PSU be enough for my config? I'm not 100% sure of using 2 cards in SLI..just wanted to know. If I do use SLI, I will spend extra money on a good PSU.
weftr100 is offline
Old 23-06-2007, 06:37 PM   #11 (permalink)
better to hv a 500 watt non sli psu frm coolermaster.
BULLZI is offline
Check Out These Cabinets Dudes tiblu Hardware Q&A 5 10-05-2006 08:46 PM
Check These Cabinets tiblu Hardware Q&A 5 19-04-2006 12:04 AM
all about cabinets... shri007 Hardware Q&A 1 21-03-2006 01:21 PM
better cabinets......help me to find it out!! thinktwice QnA (read only) 10 23-02-2006 11:14 PM
