Old 20-06-2007, 05:01 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default long beep frm a pc-it means RAM s OUT. aaa- guide me pls
dear,
PC is not switching on, whn trying to switch on, can hear a long beep sound. its the fault of RAM, i think,
can anyone guide me pls?
waiting
thanking u n advance
mobileman
mobileman is offline
Old 20-06-2007, 05:19 PM   #2 (permalink)
Default Re: long beep frm a pc-it means RAM s OUT. aaa- guide me pls
your RAM maybe loose. open ur cabinet. take out the RAM, clean its pins with a soft cloth, also clean the socket.
u can also try putting ur RAM into another socket.
kooabs03 is offline
Old 20-06-2007, 05:54 PM   #3 (permalink)
cooldip10's Avatar
There are two ways to find whether your RAM is fine or not:
1. Use another RAM in place of your RAM and then switch on.. If it starts then your RAM is gone..
2.Instead of gettting a RAM,take your RAM stick to one of your frnds and try to boot his/her computer using your RAM.
WARNING: use first suggestion with a little careful way, if your frnd's RAM blows off, you will be left to pay for his RAM also!!!
Everything is Possible
cooldip10 is offline
Old 21-06-2007, 11:20 PM   #4 (permalink)
If it's an Award Bios and the beep sound is repetitive,it could be an overheating cpu or graphics card problem.Check whether the cpu fan is moving at normal speed.
Check here for beep codes : http://www.amptron.com/html/bios.beepcodes.html
sashijoseph is offline
Old 22-06-2007, 12:26 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Do U get 1 long and 3 short beeps.....than problem is:
Extended memory failure
Ans if U get 1 long and 8 short beeps..than problem is:
display test and display vertical/horizontal retrace test failure.
RAM failure beep code is:
single beep
ravi_9793 is offline
Old 22-06-2007, 08:46 AM   #6 (permalink)
thanking u all, for guiding me well,
w ll, i have replaced to DDR 256. and it worked, but it was a celeron prossr. doe
it bear a DDR256? coz, computer working normaly, but some errors showing while booting to show desktop. and i have tried media player, it shown a msg tht, 'some enternal files are missing, reinstall it' ..!
is it due to the changing of RAM? weather i have to do any additional settings n bios or anywhere ?
waiting
Old 22-06-2007, 08:58 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
No this is not a RAM problem.
Restore your computer to best know time.
Old 22-06-2007, 02:23 PM   #8 (permalink)
Is your new ram DDR266,333,or 400?
If it's a DDR400 you may want to check your motherboard specs,whether it's supported or not.In most cases it works(at a lower freq) even if the ram's beyond the motherboard specs;but I remember a case when a similar thing was happening....files were getting corrupted.
Anyways,1st try what ravi_9793 mentioned.
Old 24-06-2007, 07:43 AM   #9 (permalink)
dear shashijoseph and others,
oky i will reinstall, the OS, bt that Ram Stick is not sutable, then how it got wtoked?'
mobileman
Old 24-06-2007, 09:06 AM   #10 (permalink)
TechTin.com
ravi_9793's Avatar
mobileman
The RAM stick must be compatible with the motherboard. Read the motherboard manual to know all sets of compatible RAMs.
Old 24-06-2007, 09:33 AM   #11 (permalink)
The system may boot but if the Ram's not compatible you may get numerous problems like BSOD,restarts,programs crashing frequently etc.
Old 24-06-2007, 10:19 AM   #12 (permalink)
TechTin.com
ravi_9793's Avatar
In this case I dont find any case of compatibility.I dont think computer will not boot using a non-compatible RAM.
If you ger error message while working ....,or sytem restarts..it means,...U may have bad RAM..or bad RAM slots.It may be possible that RAM or RAM slot has become dustly.It is a good idea to chage the slot and clean the RAM+slot if you get error messages.
Old 24-06-2007, 10:40 AM   #13 (permalink)
see your it may be damage.
abhijangda is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/60901-long-beep-frm-pc-means-ram-s-out-aaa-guide-me-pls.html
Thread New Ram and now i get long beep with no video | Computer Help Message Boards | BoardReader This thread Refback 05-10-2010 11:36 PM
vps-what does it means? kerthivasan QnA (read only) 4 26-02-2007 03:54 PM
Beep......... BBThumbHealer QnA (read only) 3 18-02-2007 08:10 PM
What does this means? hluachawngthu QnA (read only) 1 11-06-2006 10:51 PM
beep beep hang!! hearthacker QnA (read only) 2 27-12-2004 09:41 AM
