Old 20-06-2007, 01:38 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Sony DVD ritter ! ! !
which 1`s good between AW-G170A & AW-G170S ?
whots the diff ?
or which other sony drive is the best, which will read & write all types od DVD`s ?
ax3 is offline
Old 20-06-2007, 06:01 PM   #2 (permalink)
cooldip10's Avatar
Default Re: Sony DVD ritter ! ! !
Hi ax3!!
I see that you got a new Hard Disk.. Can you plz give me a little info about your purchase ? I'm also in a position to buy a new Hard Disk..
As for your question :
check the following site:
http://priceguru.in/?s=AW-G170S+
I got this much only.. BTW the dealers here recommend to go for Sony DR-170 C.. They are hassel-free.
Everything is Possible
cooldip10 is offline
Old 20-06-2007, 07:38 PM   #3 (permalink)
whots the diff ?
AW-G170s has SATA connectivity n d other has IDE...
Both're good but SATA here doesn hav much of an advantage over the other dunno why... Read frm reviews; Time fer burnin d DVDs/CDs're jus the same!!!
SATA of corz reduces clutter coz of the thinner cable n help u organize ur system well...
Jus a matter of 200-300 price diff....
Well... D above both're good...
As he said DRU-170c is also gr8... a newer model..
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 21-06-2007, 11:32 AM   #4 (permalink)
ax3
ax3's Avatar
thanx 4 the replies ........ bt still confused ....... & these dealers make u more ....... just visited a shop @ lam. , he made my head more in a rotating position ..... he says "sony bad, go 4 liteon" .........
@cooldip10 ......... just got myself an internal hdd ....... western digital 160 gb hdd ...... 4 3200rs ....... bt made it external using trandscend casing 4 750rs ......
ax3 is offline
Old 21-06-2007, 12:58 PM   #5 (permalink)
160Gb fer 3200??? Inclusive of the transcend casin I believe...
Old 21-06-2007, 04:16 PM   #6 (permalink)
ax3
ax3's Avatar
no frd ......... trandscend casing 4 750rs ......
ax3 is offline
Old 21-06-2007, 05:15 PM   #7 (permalink)
cooldip10's Avatar
How come you boot then?? Can you boot from USB HDD??
BTW good deal :: Rs 3200 for 160 GB.. just great
You know a dealer here (beside my vicinity) says a 80 GB would cost me around Rs 2.9K .. Now 160 GB HD seems a good one!
Old 21-06-2007, 05:28 PM   #8 (permalink)
ax3
ax3's Avatar
prices r falling ......... & so is THE QUALITY ............
i just plugin my new USB HDD & take backup .........
i dont know any dealers in delhi ....... sorry frd ........
ax3 is offline
Old 21-06-2007, 07:18 PM   #9 (permalink)
Why 160GB fer 3200??? I dun get it...
Old 22-06-2007, 12:41 PM   #10 (permalink)
ax3
ax3's Avatar
I dun get it... whot u wanna say ?
ax3 is offline
Old 22-06-2007, 01:01 PM   #11 (permalink)
Hws 160GB fetchin 3200?? The thing costs somethin around 2.3k na???
Old 22-06-2007, 04:21 PM   #12 (permalink)
ax3
ax3's Avatar
oooh no ....... has my dealer cheated on me ?
comming back 2 point which dvd writter should i go in 4 ?
liteon or Sony .......... model no. plz ..............
ax3 is offline
Old 22-06-2007, 04:26 PM   #13 (permalink)
LOL!!!
Your dealer is a dacaith!!
80GB shouldn't be more than 1800/- and 160gb - 2400/-
sashijoseph is offline
Sony Ericsson W850i vs. Sony Ericsson K800i (Walkman vs. Cybershot) soumya Mobiles and Tablets 10 03-10-2008 02:23 AM
External DVD ritter ! ! ! ax3 QnA (read only) 3 09-05-2007 01:06 PM
Which dvd-writer sony dw-q120a or sony dru-820a its urgent anirudhasarawgi Hardware Q&A 3 27-05-2006 05:47 PM
Everything on the SONY PSP sagsall4u Mobiles and Tablets 15 22-07-2005 10:24 AM
Sony PS3 is Here rajesh Gamerz 1 17-05-2005 11:23 AM
