Old 19-06-2007, 11:55 PM   #1 (permalink)
Angry dvd writer cannot play audio video dvd
My asus dvd dual layer writer (DRW 1608 P3S) cannot play audio and video dvd even cannot recognize it. What may be the cause and solution? Please respond quick.
Thanks all. jenaguru.
jenaguru is offline
Old 20-06-2007, 12:39 AM   #2 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Default Re: dvd writer cannot play audio video dvd
has dvd detected in my computer or explorer? if not then there is prob in dvd disk.
bhushan05d251 is offline
Old 20-06-2007, 08:21 AM   #3 (permalink)
try cleaning the lens.....
iammrcool is offline
Old 20-06-2007, 08:45 AM   #4 (permalink)
TheSaint
NucleusKore's Avatar
If its a new one please get it replaced. My experience with DVD writers hasn't been as good as cd writers. I just returned my Sony DRU-170C. It wasn't reading half my DVDs (Data DVDs) which used to open in other drives including Samsung drives! If its new and under warranty, let the company do the lens cleaning or whatever, don't fiddle with it
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 20-06-2007, 01:44 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
replace it ............
ax3 is offline
Old 23-06-2007, 02:28 PM   #6 (permalink)
problem is strange than u think. it is reading data dvd perfectly, but not audio and video dvd.
any more suggestion than getting it replaced?
thanks.
jenaguru is offline
Old 23-06-2007, 04:38 PM   #7 (permalink)
Hi,
What format (video) discs does it reject....pressed dvd-rom,DVD+R,DL etc or all of them?Maybe it dislikes a particular disc format,say DVD+R.
Also try different brands.
Try video discs with diff. formats,or burn one and see.
Also look for a recent firmware.
If all else fails,open it and clean the lens with a soft clean moist cloth.
Finally dump it and get a new one.
sashijoseph is offline
Old 23-06-2007, 05:38 PM   #8 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Burn a Disc urself and see if it runs. Maybe those you are trying are of diiferent kind. They may be DVD-RAM.
Quiz_Master is offline
Old 23-06-2007, 10:54 PM   #9 (permalink)
I tried with a rented video dvd, so dont know which format ( -R or +R etc.)
Audio dvd i tried with both -R and +R and I burned it myself by that writer perfectly. Lens is cleaned. I am puzzled.
thanks again.
jenaguru is offline
Old 23-06-2007, 11:49 PM   #10 (permalink)
TheSaint
Originally Posted by jenaguru
I tried with a rented video dvd, .....
thanks again.
Scratched rental DVDs will trouble you
Old 23-06-2007, 11:55 PM   #11 (permalink)
If u want to see that video only then i can give u temporary sol.
forget about anything. just open Nero Vision Express (if u have installed nero entire bundle) all programs->Nero Ultra->Photo and Video->Nero Vision Express.
Then select create VCD or DVD or any other format. insert ur Video disk. then select import disk (or video i donno exactly) select ur drive. Nero vision will detect that video files. select all chapters (or titles). select location to save. n ok. it will save in .mpg format automatically. then copy that entire saved folder to other drive or to other folder (bcoz when u exit temp files will be deleted). close nero. now u can open through wmp or any player.
Just try. i think it will work.
Old 24-06-2007, 12:19 AM   #12 (permalink)
spyingshadow's Avatar
The problem can also be caused if u hv installed InCD by Nero. Once i had instaalled it n my DVDs in UDF format refused to run, including my movies n all. Just check if that's the case..... (PS I"M FRESH STOCK)
Cant catch vot ya cant see 8-)
spyingshadow is offline
audio doesnt play in movies sagargv Software Q&A 16 09-06-2007 04:47 PM
what is audio book? how to play it in iPOD? kerthivasan Audio 3 25-02-2007 11:43 PM
How to play audio & video on any linux? wizerd Open Source 15 13-02-2006 11:25 PM
Window Media Player 10 can't play Audio CD debrajrakshit Software Q&A 5 14-12-2005 11:12 PM
Audio CDs don't play in XP---HELP serendipiti Software Q&A 2 04-07-2005 04:28 PM
