Old 19-06-2007, 09:47 PM   #1 (permalink)
Exclamation Plz help - Computer needs power!!
My comp won't start for the last few days. When I switch on my UPS, everything is fine; the lights on the keyboard blink once, and like that. But the moment I press the power button on my cabinet to start my machine, the power comes and Immediately goes off!! The LEDs (there are two - Green for power & Red for hard disk) glow and immediately shut down. The fans inside start to run & immediately lose power and come to a stop!!
Oh, and one more thing - if I press the power button for any more times, whatever activity mentioned above, stops. No activity this time at all!! BUT, if I keep pressing the power button for 11-12 seconds (which I sometimes use to shut down the machine in case it hangs - I'm told that's the purpose for pressing it for a long time) and then again press the power button normally to start, the power comes and goes out, just as I described in the above para.
People Plzz help me; I can't seem to find a way out!!
abhra is offline
Old 19-06-2007, 11:31 PM   #2 (permalink)
Default Re: Plz help - Computer needs power!!
Can be a faulty PSU... Les make sure the rest of the home work's done prior to dat...
Replug all d Power cables frm d PSU.... Check d i/p cables frm the cabby dat plugs to ur mobo... Replug dat as well... Re-insert RAM modules.. Make sure ur VGA card's seated prop...
Now restart...
If it does d same thing... Check ur system with ur friends PSU..
If its a faulty PSU causin u a problem, invest in a good one...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 21-06-2007, 07:13 PM   #3 (permalink)
Can someone recommend a good PSU; I mean, what brand & what current or power values, and the like??
abhra is offline
Old 21-06-2007, 10:04 PM   #4 (permalink)
Is actually a real word..
It could also be your BIOS/CMOS battery is dead (little watch battery) need more specs on your computer and what you intend on using it for to determine a good PSU, try a PSU calculator here is an example of one http://files.pcapex.com/details.php?file=19 this may help wyou with what you may need.
Liggy is offline
Old 23-06-2007, 08:54 PM   #5 (permalink)
Well mine is an old machine - Intel P4 1.7 GHz processor, Mercury KOB 845G NDS Mx mobo, 256 MB RAM, 40 GB Seagate HDD, 1 DVD-CDRW combo drive. That's it. I use it mainly for some programming, office applications, and a few games (not hardcore ones; I have onboard graphics so not much memory).
What rating (in volts) should this battery have(there's nothin written on top of it)? Its running for 2 years now, I don't think it is down; will check it though.
And again, if I have to change my SMPS, which brand do I go for? And what rating??
I was reading in this forum that today's cabinets come with PSUs, mostly 450 W, bundled with them. Changing the cabinet is exactly what I am planning to do immediately. So, which cabinet - I mean, which brand - should I go for? I need an ATX form-factor cabinet, and with my config given above, will the bundled (if any) SMPS be enough??
abhra is offline
Old 23-06-2007, 09:12 PM   #6 (permalink)
Ya,for your config the bundled psu should be enough.Look for i-Ball,Zebronics etc
sashijoseph is offline
Power consumed by computer Sridhar_Rao QnA (read only) 5 13-03-2007 05:07 PM
Computer boots automatically on power on... sushantasarkar Hardware Q&A 1 11-11-2006 11:42 AM
Help my computer work during power failure sysmaniac QnA (read only) 1 21-06-2005 10:02 AM
