Old 19-06-2007, 11:53 AM   #1 (permalink)
Bula! Namste
milnniki's Avatar
Default acer motherboard ( intel 82845 g) sound driver needed
hi guys
if u know tell me buddy
thanku very much
"Think big, think fast and think ahead.
Idea is monopoly of nobody." - Dhirubhai Ambani
milnniki is offline
Old 22-06-2007, 11:59 PM   #2 (permalink)
Is actually a real word..
Default Re: acer motherboard ( intel 82845 g) sound driver needed
yeah Acer great for that I have two Acer's and can never find anything on their website... why do you need the sound driver (did you recently format) is it a AC 97 (realtek/soundmax audio) if so I can give you a file which is suppose to be compatible with almost all intel's AC 97 sound integrated sound cards. you should have an Acer recovery disk or similliar with the drivers on there. I had problems with my driver and I downloaded Direct x 9c, which solved my problem then they put out a new driver.
Liggy is offline
Old 23-06-2007, 12:02 AM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
if you have onboard REALTEK Audio solution, then d/l the driver from here http://www.realtek.com.tw/downloads/
ASUS K53SV SX520D + BF3
s18000rpm is online now
A new graphics card driver for intels 82845 chip Amir.php Graphic cards 3 03-02-2007 03:52 PM
didnt found driver for acer travelmate 341 Saharika Software Q&A 3 26-12-2006 07:59 AM
WHERE SHOULD I GET LATEST DRIVERS FOR intel{R}82845 Nilesh.Ravindran Gamerz 2 11-12-2005 10:08 PM
