Old 19-06-2007, 02:36 AM   #1 (permalink)
anarchy0x's Avatar
Default which is faster?
I have a 320 GB SATA & a 40 GB PATA
Which of them should I use for installing XP so that programs run faster?
40 GB must be faster than 320 GB coz of its larger size
But the 320 GB is a SATA drive which is supposed to be faster than a PATA drive
thanks in advance for solving my dilemna
anarchy0x is offline
Old 19-06-2007, 09:51 AM   #2 (permalink)
darklord's Avatar
Default Re: which is faster?
320 will be faster because it is SATA and most probably it will be 7200.10 series which is perpendicular recording.
This stands true assuming your 40GB PATA is older drive.
darklord is offline
Old 19-06-2007, 08:41 PM   #3 (permalink)
t3h g04t
teknoPhobia's Avatar
The 40 Gb is far slower the 320 GB, rule of thumb, all else being equal, bigger the HDD, faster it is.
technologically challenged.
teknoPhobia is offline
Old 19-06-2007, 08:56 PM   #4 (permalink)
Eh wat the???
Who said dat???
U mean to say a WD Raptor 150Gb will perform faster than a ~ WD Raptor 74GB???? ( I mean jus fer comparisons...)
Guys jus make dat point clear plz... neve heard of dat before...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 19-06-2007, 09:07 PM   #5 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Don't think more. Just install XP on ur SATA drive.
bhushan05d251 is offline
Old 19-06-2007, 10:31 PM   #6 (permalink)
sumeet singh's Avatar
Cool Re: which is faster?
hmmm:
I am nOt paId EnOugH tO bE nIcE tO U!!!
sumeet singh is offline
Old 20-06-2007, 12:49 AM   #7 (permalink)
deathvirus_me's Avatar
Hmm , never noticed any performance difference between XP on SATA and XP on PATA ... yes ... 5400 rpm hdd with lower read buffers will mean slightly more access time , but not something drastic .. finally , it depends on how well ur XP is optimized for its performance ..
If u really want more performance out of the SATA hdd than over ur PATA , just keep the page file on the SATA drive , no matter where u install XP ..
The performance boost when using SATA drives is noticeable only when u run two or more drives in RAID ..
deathvirus_me is offline
Old 20-06-2007, 04:24 AM   #8 (permalink)
anarchy0x's Avatar
Thanku all for replying. I guess I ll use SATA
Which is Faster & y? Mangal Pandey QnA (read only) 10 17-02-2007 02:47 AM
Tweak Win Xp to be FASTER! johntp Tutorials 5 16-01-2006 12:56 AM
how come sata is faster..... manmay QnA (read only) 1 03-01-2006 01:34 AM
Kaun faster hai? linardni QnA (read only) 11 28-09-2005 08:18 PM
