Old 18-06-2007, 05:56 PM   #1 (permalink)
papai_mcc's Avatar
Question Buying laptop
could any one suggest me a laptop around Rs.40000/- for the purpose desktop work and some photoshop work.Help is solicited.Thanks in advance.
View My Photo Gallery: http://the3rdeye.co.cc
papai_mcc is offline
Old 18-06-2007, 06:20 PM   #2 (permalink)
Default Re: Buying laptop
check this out
http://www.thinkdigit.com/forum/showthread.php?t=60121
kooabs03 is offline
Old 18-06-2007, 07:05 PM   #3 (permalink)
papai_mcc's Avatar
Thanx 4 the reply but I am searching for a new one.
Old 18-06-2007, 07:12 PM   #4 (permalink)
Beware of the innocent
ilugd's Avatar
any normal laptop with 1 gb ram would suffice i think.
Life is too short. Have fun.
ilugd is offline
Old 19-06-2007, 11:14 AM   #5 (permalink)
lenova or hp is best , i think lenova is not in your budget with good config , but hp is still best
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 19-06-2007, 01:15 PM   #6 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
u should go for dell inspiron 1501.it is the best u can get for 40k....increase the ram to 1gb & u could choose a better processor if it fits ur budget..
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 21-06-2007, 12:25 AM   #7 (permalink)
papai_mcc's Avatar
Thanx a lot to every one
Old 21-06-2007, 12:45 AM   #8 (permalink)
lenova is the best or get an hp
MY TECH BLOG - www.technicaltricks.blogspot.com
nobody.is.perfect.eME is offline
Old 21-06-2007, 01:04 AM   #9 (permalink)
^^^ lenovo.... Ahem....
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 21-06-2007, 01:09 AM   #10 (permalink)
Rebooting
Choto Cheeta's Avatar
http://www.hclnotebooks.in/product_d...code=AX00V2002
Ask the dealer to upgrade the RAM to a 512x2 = 1GB RAM module from company to receive warranty on full system,
in Kolkata its around 33k to 35k + TAX with 1GB upgrade ... depending on the store Type !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 21-06-2007, 11:00 PM   #11 (permalink)
RiGhT HeRe RiGhT nOw
ashishnehete's Avatar
U can get the best config from dell in 40K
u can to bargain from them to discount the taxes if out of mumbai
ashishnehete is offline
help me buying a laptop sidhu1990 QnA (read only) 3 25-04-2007 09:45 PM
Need help in buying Laptop!! nach p Laptops and Netbooks 1 18-09-2006 03:57 PM
Need help buying Laptop... shariq_pj Hardware Q&A 3 18-12-2005 10:01 PM
Buying A Laptop er.darshan QnA (read only) 94 16-06-2005 12:50 PM
Buying a Laptop Pragna QnA (read only) 14 06-06-2005 01:17 AM
