Old 17-06-2007, 10:27 PM   #1 (permalink)
I see right through you.
Sykora's Avatar
Default Help needed with P5B Deluxe.
I just bought my new rig, and I'm having problems off the bat with my motherboard. The two things I need help with right now are these :
1. I get a "Detect drives done, no any drive found" error. (Look here to see exactly what I mean : http://www.andytaro.com/images/load1.jpg). I have no idea what this is supposed to mean, but the more pressing issue is...
2. My BIOS does not recognize my Liteon DVDRW. Because of this, I can't set it as a boot device, and I can't do anything with it. My hard drives are both empty.
Any suggestions?
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 18-06-2007, 01:53 AM   #2 (permalink)
assasin's Avatar
Default Re: Help needed with P5B Deluxe.
did ya try to connect ur dvd-rw witha diff ide cable?did u check that the J-micron controller is enabled from BIOS?also try with a diff power connector molex.
assasin is offline
Old 18-06-2007, 08:02 AM   #3 (permalink)
Sykora's Avatar
I think the power connector is fine, because the tray ejects properly. Under 'Onboard devices', it says it's using a J-Micron SATA/PATA Controller, so I guess that would be it. I'll try a different IDE cable though. I'm just wondering whether it's a hardware problem, or a bios problem.
-- Sykora --
Sykora is offline
Old 18-06-2007, 08:17 AM   #4 (permalink)
Dark Star's Avatar
1'st of all Lite On sucks .. Note this in mind .... Lite on sucks .. Try flashing the BIOS my friend has some problem when I flashed the BIOS problem gonbe... Note again never buy LITE on :::::::::::::::::X
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 18-06-2007, 08:59 AM   #5 (permalink)
Sykora's Avatar
Thanks for the vote of confidence, Shashwat Pant. You should have told me that a week ago.
Anyway, it works now. Turns out it was a faulty IDE cable.
-- Sykora --
Sykora is offline
Old 18-06-2007, 11:26 PM   #6 (permalink)
assasin's Avatar
@Shashwat Pant LiteOn doesnt suck,its one of the best drive's around.
assasin is offline
Old 18-06-2007, 11:40 PM   #7 (permalink)
Anindya's Avatar
Question Re: Help needed with P5B Deluxe.
What`s this J-micron? Plz let me know.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 19-06-2007, 09:54 AM   #8 (permalink)
darklord's Avatar
Since ICH8 [that is the Southbridge for Intel P965 series chipsets] removed native PATA support altogether.it was stupidity for mobo makers not the give PATA ports on their mobos as people are still using PATA devices.Hence mobo makers installed third party IDE controllers on their boards.In case of Asus P5B Deluxe and Asus P5W-DH Deluxe, Asus used IDE controller made by 'Jmicron' which supported 1 IDE channel and 2 SATA Ports IIRC.
Hope that clarifies your doubt.
darklord is offline
P5B Deluxe WiFi-AP assasin Hardware Q&A 97 02-04-2009 10:58 AM
Should I sell my A8N SLI Deluxe geek Hardware Q&A 8 18-06-2006 01:46 PM
A7N8X-E DELUXE - help! icecoolz QnA (read only) 8 18-10-2004 11:45 AM
