Old 17-06-2007, 12:25 PM   #1 (permalink)
Default AMD vs INTEL ?????
which processor is better for the money we spend and for gaming
ravz is offline
Old 17-06-2007, 12:37 PM   #2 (permalink)
Default Re: AMD vs INTEL ?????
i would say the amd . especially the 5000+ and 5200+ X2 which are better priced when compared to Intel C2D 6320
sagsall4u is offline
Old 17-06-2007, 02:12 PM   #3 (permalink)
deathvirus_me's Avatar
Depends on ur usage .. if u wanna just plug in and forget about things , then AMD all the way . if u really wanna OC the hell out of the CPU , then Intel ... not that AMD' wont oc ,,, but this is just a simple comparison ..
deathvirus_me is offline
Old 17-06-2007, 02:22 PM   #4 (permalink)
if u wanna OC' then go for intel, if not then go for AMD(gives more value for money on stock speed)
kooabs03 is offline
Old 17-06-2007, 02:30 PM   #5 (permalink)
::cyborg::'s Avatar
A M D
:-d
:)) - KEEP SMILING
::cyborg:: is offline
Old 17-06-2007, 06:20 PM   #6 (permalink)
It's me.....
Matrix's Avatar
I'm using AMD 4200+ x2 ...it's rocking gr8 there r no words to explain it....Intel far behind...even i can't him....is it coming...haha
but with atleast 1GB 800MHz RAM .
Matrix is offline
Old 17-06-2007, 07:07 PM   #7 (permalink)
Anindya's Avatar
Those supporting AMD 5000+ can u people plz tell me how u all r suggesting that procy and telling that its price is lesser than 6320? Coz in the theitwares the price of 6320 is given Rs.7750 and 5000+ Rs.8100. And if u visit this http://xbitlabs.com/articles/cpu/dis...0_7.html#sect0 u will see that they r quite head to head. No grudges plz just want to know the truth.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 17-06-2007, 07:27 PM   #8 (permalink)
Intel hands down as of now...
I mean dun let the proccy sit idle; so go n extrzct evry juice outta dat C2D proccy n AMD wudn get close enuf...
AMD + AMD mobos're cheaper options as of now... Fer the casual gamers as well.. Intel mobos come @ a premium as always...
Intel as of now...
Without doubt the E4300.... O'clocks @ 3Ghz really well n ther're ppl who've done it with Intel Retail coolers itself... It'll easily surpass AMDs' till the X2-5000!!!!
But u need a good o'clockin mobo @ 6k... Like D XFX 650i ultra whick helps o'clock better...
Ther's a newer proccy in Intel- E2160...
Frer ur kind info, d Intel E2160 easily o'clocked till 3.6Ghz with Aftmkt coolers and easily overtook the QUAD 6600(If M not mistaken)... Yes D quad proccy...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 17-06-2007, 07:41 PM   #9 (permalink)
Google Bot
Pathik's Avatar
^^ wat abt the difference in l2cache??? and i suppose that during the comparision the 6600 wasnt OCed??
Pathik is offline
Old 17-06-2007, 08:01 PM   #10 (permalink)
Dark Star's Avatar
Depends in simple words.. OC --> Intel
No OC--> AMD...... Btw Oc is not a tough matter so I would go Intel way currently Listen being a fanboy of any brand is not a good thing there are ups and downs every day. So being a fanboy is not good. 1 should buy 1 which is leading And the war btw these giants will give benefit to user as better products at lower cost are available
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 17-06-2007, 08:29 PM   #11 (permalink)
^^^ey hey no one's fanboy...
Over the years I've used both proccys...
AMD k6-2---->Intel p3 1Ghz---->AMD Thunderbird 1.2Ghz----> AMD Athlon Xp 1800+----> Intel p4 2.4 Prescott----> Intel P Extrm Ed 3.2---> AMD Athlon 64-3500+
Gulp... Dood pathiks, my bad... Its not a quad... Its an Extreme!!!
Jus checked xbitlabs fer d review...
Here:
http://www.xbitlabs.com/articles/cpu..._14.html#sect0
Core 2 Extreme
X6800
Besides its 1mb L2...
Old 29-07-2007, 12:46 AM   #12 (permalink)
dhan_shh's Avatar
How is AMD Turion compare to Intel Centrino?
Anyone with personal experience,Kindly share your views,plz..!!!!!!!!!
dhan_shh is offline
Old 29-07-2007, 01:08 AM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
Best for gamin Intel C2 extreme series
ravi_9793 is offline
Old 29-07-2007, 08:34 AM   #14 (permalink)
Dark Star's Avatar
Hardly much diff in Higher C2D and Extreme C2D So not much in Real world
Old 29-07-2007, 12:18 PM   #15 (permalink)
The Frozen Nova
casanova's Avatar
A simple comparison between the working of Intel and AMD proccies.
Task: Take 10 litres of water from Point A to Point B.
Intel: Take 1 litre of water from Point A to Point B. Repeat it 10 times. (Less work, more cycles)
AMD: Take 5 litres of water from Point A to Point B. Repeat it twice. (More work, less cycles)
www.nerdweed.blogspot.com
casanova is offline
Old 29-07-2007, 12:37 PM   #16 (permalink)
speedyguy's Avatar
good one casanova...
som1 askd abt turion n core 2 duo...as of now its core 2 duo....
turion also has some issues wit current most laptops having nvidia n vista combo....core2duo is less heat generating n more compatible 2 vista...m facing it
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 29-07-2007, 02:12 PM   #17 (permalink)
Distinguished Member
anandk's Avatar
http://www23.tomshardware.com/cpu.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 29-07-2007, 06:36 PM   #18 (permalink)
tech mighty
arun_chennai's Avatar
Buy E4400 and overclock it to 3GHZ....it will beat the whole AMD lineup...
arun_chennai is offline
AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D vish786 Technology News 9 09-06-2007 07:46 AM
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
intel 2.8 and intel 2.8 HT freakabhishek Hardware Q&A 9 08-05-2006 03:26 PM
INTEL 865 GBF techsammy Hardware Q&A 7 27-03-2006 06:56 PM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
