Old 16-06-2007, 01:11 PM   #1 (permalink)
Default MOBO for Intel 478 pin CPU
HI,
I need a suggestion about a motherboard for Intel 478 pin CPUs offering best onboard graphics and an AGP port...
I already have
P4 2.8 GHz (478 pin)
512 MB DDR 333
ashnik is offline
Old 17-06-2007, 06:04 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: MOBO for Intel 478 pin CPU
go & buy MSI PM8M-V
http://global.msi.com.tw/index.php?f...=1&cat2_no=170
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 17-06-2007, 05:29 PM   #3 (permalink)
cooldip10's Avatar
I recently went to Nehru Place in Delhi and to my surprise socket 478 mobos are out of stock!! Man in a place like Nehru Place it was weird...
You most probably won't get a new mobo for socket 478 cpu. Since the mrkt is flooded with LGA 775 sockets which support C2D
I was lucky to get a 2nd hand GIGABYTE mobo and its perfectly fine.
Mobo: GIGABYTE 82845GE RZ
Spec: Supports HT technology socket 478 CPU.
3 memory modules capacity.
AGP 8x slot.
cost : Rs 1.7K with 8 months warranty.
Try searching a lot before you get your choice of mobo.. Best of Luck
Everything is Possible
cooldip10 is offline
Old 17-06-2007, 07:12 PM   #4 (permalink)
Originally Posted by ashnik
HI,
I already have
512 MB DDR 333
The intel 865 GBF... Twas d Digit Best PErformeer wen they'd reviewed it those days in d mid-series mobos...
Shud be still available... Better hurry...
HAs good onboard 5.1 sound and supports sata as well....
Dis mobo has a better bro- 875 jus like our present chips-965 & 975...
Check out dat as well..
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 18-06-2007, 11:11 PM   #5 (permalink)
thanks guys....
ashnik is offline
Old 19-06-2007, 06:21 PM   #6 (permalink)
I M BACK , WITH A BANG
saggygenius's Avatar
dont waste money buying a 478 mobo,
thats useless,
upgrade ur PC, with a AM2 processor with onboard gfx,
please mention ur budget , if u want the config,
My Greatness Cannot be Expressed in Terms Of normal Word's,It Requires a Compiler
-By saggygenius
saggygenius is offline
Old 20-06-2007, 10:27 AM   #7 (permalink)
cooldip10's Avatar
thats useless,
hey a 2.6 Ghz cpu is not bad to work upon.. I think its the user's choice to move on to other socket type by extending the budget..
Old 20-06-2007, 01:50 PM   #8 (permalink)
well , when u get to work on vista , then u will come to know that wat's bad & wat's good,
-By saggygenius
Old 20-06-2007, 05:38 PM   #9 (permalink)
cooldip10's Avatar
I still don't think 2.66 Ghz is less to run Vista.. As more of its components are dependent on GFX memory
Old 21-06-2007, 12:54 PM   #10 (permalink)
thabks guys 4 ur help..
It's a P4 2.8 GHz, very good CPU still.
BTW I am gonna buy mobo only, no upgrade to AM2, as the main intention of this mobo is to sit in office and run Tally, MS Office etc.
Peace
MODs PLZ lock the thread
ashnik is offline
Old 21-06-2007, 05:16 PM   #11 (permalink)
cooldip10's Avatar
Hey we are not fighting seriously.. It was just a healthy argument!!
Old 21-06-2007, 09:11 PM   #12 (permalink)
rohit_bawa's Avatar
i think Ghz does not matter its the performance, i came across a system at a store which was running vista with celeron 3 Ghz and 1Gb+ ram
And its rating was '1'
rohit_bawa is offline
Old 21-06-2007, 09:53 PM   #13 (permalink)
Is actually a real word..
So I don't understand, what's the verdict what should Ashnik buy. I too would like to upgrade my board. actually I tried that awhile ago bought a $40 SIS board on ebay and had it crap out on me in two months. my sys is basically the same. Mine is missing the AGP slot, hence why I want a different board (use it for ACAD and the odd game). have 2.6 Ghz,768 MB DDR 333. we are just simply lookin for a board.
Liggy is offline
Old 21-06-2007, 10:27 PM   #14 (permalink)
Cool G5's Avatar
Post Re: MOBO for Intel 478 pin CPU
Go for MSI PM8M-V.Gr8 mobo for 478 pin cpu.
Cool G5 is offline
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
want mobo for intel c2d e6300 nishant872 CPU / Motherboards 2 13-11-2006 01:41 PM
plz suggest intel mobo for cad/cam ashnik Hardware Q&A 2 07-02-2006 01:33 AM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
