dear,
i m using P4 2.6.
this was happend first. whn turning on the pc, it will boot, thn while loading XP, skipping to the restart. wht my thought was, this may be due to out of memory. i have doubled mmc.still same effect.
today wht i done is, booted frm XP cd, then it workd the setup and all. it a ked whr P to be ibstalled, i have sected C:. it checked, and skipped by showing a msg tht, C: containing non repaired errors,fix thm first. wht i done is, thr fdisk, formated C: and tried to install Win 98se. Everything worked fine first, and again showed tht, in d ive C: containing large no od bad sectors, fix it or read setup.txt in disk vol 1. i have some questios to sort out, thats;
1) wht and hw these problam occured?
2) hw is the remody?
pls be kind to guide me to use my PC
Thanking u
waiting
mobileman
can someone send me PM too,in this regarding
