Old 16-06-2007, 06:36 AM   #1 (permalink)
Default Automatic shutdown?????
i have windows xp pro O.S and start a computer with work it works fine but a 10 minuate it suddelnly shutdown the PC. The Starnge Thing is That Processor Is Running AND while i am pressing the restart button it doesn't work.
processor------AMD 64*2 Dual core
Board ---------MSI K9NGM
Harddisk-------80GB Sata + 250GB sata
RAM-----------256*2=512 [533 megaherts] + 1GB [533 megaherts]=1.48 G.B
Normal software loaded and 650 Wats SMPS
kiranbajpe is offline
Old 16-06-2007, 09:34 AM   #2 (permalink)
assasin's Avatar
Default Re: Automatic shutdown?????
try running only with the 1GB stick.
assasin is offline
software for automatic shutdown timer intel_outside Software Q&A 8 08-12-2006 04:03 PM
Automatic Power on and Shutdown deadly_dude QnA (read only) 7 23-06-2006 12:00 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
Automatic shutdown software naru Software Q&A 15 24-10-2005 06:30 PM
