Old 15-06-2007, 10:11 PM   #1 (permalink)
manishjha18's Avatar
Default ddr 1 ram problem
have an asus a8v-mx motherboard..i had a ddr400 ram (dynet) i just bought a new ram 1gb ddr400 (transcend) my comp doesnt go on with the other ram in..it doesnt give the motherbord beep only..iv tried the ram and the old ram together and only the new ram..no luck..the comp works fine with the old ram..any suggestions?
thnks..
manishjha18 is offline
Old 15-06-2007, 10:58 PM   #2 (permalink)
Alpha Geek Banned
bikdel's Avatar
Default Re: ddr 1 ram problem
most probably the old ram is malfunctioning...........
did u try changing the slot in which u put the new ram?.......
if it works in other slot then ur mcb maybe bad.....
by the way how much did that transcend 1 gb stick cost to you?.......
im planning to get one now as my 256 mb is just not enough.......
bikdel is offline
Old 15-06-2007, 11:26 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
First try with single ram ....and d/l CPU-z and mem test +.....use it and check teh reports..uisng CPU=z get latency of ur both ram..set ur mobo latency form BIOS to lowest of both ram..adn then try using both......
does the new single ram work..when installed without old ram? ????
wizrulz is offline
Old 15-06-2007, 11:39 PM   #4 (permalink)
no yaar the new single is also not working thats whats bothering me..i cant even test it..u know the motherboard isnt giving the series o beeps it gives if no ram is present but it isnt giving the single beep also of the comp booting..
btw i got it for 3000/- here in pune
Old 15-06-2007, 11:42 PM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
so get it replaced....or tested on frnds comp before going and fighting with seller
wizrulz is offline
Old 16-06-2007, 12:16 AM   #6 (permalink)
Ya i was going to do that..just wanted to make sure i wasnt doing nethig wrong
thnks..
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
