Old 15-06-2007, 04:29 PM   #1 (permalink)
free as a bird
Thumbs down another hard disk
hello
my sytem has a primary mas dvd burner and seagate 80 gb as prmary slave
and secondary master as cd burner and secondry slave as dvd drive and now i want to add one more hard disk drive plz help
vicky_l7 is offline
Old 15-06-2007, 04:32 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: another hard disk
What is your Motherboard ??
as seems that you have eaten up all the IDE connection ports !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-06-2007, 09:29 PM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^looks like it
btw, go in fer a SATA disk dude if thats the case, i.e, if ur mobo supports it
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 15-06-2007, 09:34 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
You'd need an IDE expansion slot to affix more than the default.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-06-2007, 11:14 PM   #5 (permalink)
Alpha Geek Banned
bikdel's Avatar
Many solutions are available
1. if ur motherboard supports, go for SATA harddisk
2. if it does not then buy another PCI ide controller which u'll be able to use alongside the mcb's IDE controller
3. If not then u can buy an external USB hardisk
4. If u have to use internal hardisk then u can buy a USB to IDE cable..... u wont get these everywhere.... i got them at ebay.com
5. Lastly...... the simplest one.... sell off the cd burner and use the vacant ide port.....lol
hope that helps
bikdel is offline
Old 16-06-2007, 12:56 PM   #6 (permalink)
club_pranay's Avatar
nice one bikdel!! the best option seems to be the fifth one!(if u dont have sata)
but option 1, SATA(if u have one) would be better!
u realy dont need a seperate cd writer, along with a dvd burner!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Hard Disk(160 gb) GeekyBoy Hardware Q&A 15 16-05-2007 03:35 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
RAW hard disk sweetricha07 Hardware Q&A 1 04-11-2006 09:27 PM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
