Old 14-06-2007, 02:30 PM   #1 (permalink)
Unhappy SATA Drive Help!!!
I have A MSI K8M Neo-V Mobo and I recently brought seagate Barracuda SATA 160 GB HDD...
When I tried to install Win XP it Didn't Detect the HDD...
The HDD is also NOt detected in WindowsXP SP2 that is installed in My Older Drive....
Please help!!!
Thanks
Sumit Kumar is offline
Old 28-06-2007, 12:56 PM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: SATA Drive Help!!!
during intallation press F6 for third party driver
coz xp dont ve sata driver inbuilt
u got a floppy with sata hdd
when it ask for third party driver
press S and then insert flopy
now system copies the required file and detect ur hdd
now u r ready to go
hope it ll help u
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 28-06-2007, 01:34 PM   #3 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
detection of sata depends on ur bios too..
btw did u get a proper power cable..
coz wen i purchased a sata.. i got a faulty cable..
so check if ur sata disk is running wen ur pc is on..(touch n c for some kinda vibrations)
spynic is offline
Old 28-06-2007, 02:17 PM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
now u r ready to go
hope it ll help u
Thats is for setting up RAID my friend
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 28-06-2007, 05:55 PM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
now u r ready to go
hope it ll help u
eep this is for setting up RAID man you dont need any drivers for setting up SATA drives...........
to the OP what does your BIOS show, does the HDD show up there.??
sam9s is offline
Old 29-06-2007, 08:08 PM   #6 (permalink)
press f6 when setup started and install raid driver through floppy.
abhijangda is offline
Old 29-06-2007, 10:14 PM   #7 (permalink)
Host4Cheap.org
I dont know why people are suggesting RAID. The HDD should be detected by PC. Check Cables is my suggestion and also check if it shows in BIOS
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
mounting sata drive & pen drive vish786 Open Source 9 11-05-2007 07:14 PM
Not detcting sata drive... Caesar Hardware Q&A 1 20-04-2007 02:37 AM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
BEST SATA DRIVE Prajith QnA (read only) 4 08-07-2005 11:44 AM
