Old 14-06-2007, 12:58 PM   #1 (permalink)
cooldip10's Avatar
Default Waves!!
Hi guys!!
Finally I was able to change my config.. but with old processor (P4 2.4GHz)
The gfx card which I got is : nVidia GeForce FX 5200 by Zebronic (256MB)
Mobo: GIGABYTE 82845GE RZ
Now the prob is:
I have an LG monitor in which some kind of waves are appearing (sometimes).This is causing a lot of irritation when watching movies or TV and while working also.
While playing games also sometimes this happen but otherwise games run fab. fine.
Is there any soln. for this..
Everything is Possible
cooldip10 is offline
Old 14-06-2007, 01:58 PM   #2 (permalink)
Hells_Fury's Avatar
Default Re: Waves!!
Are your speakers placed near the monitor? Looks like there is some interference with your monitor. Try moving your monitor such that no other device is near it and then check if this still happens.
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 14-06-2007, 02:09 PM   #3 (permalink)
Default Re: Waves!!
Try degaussing the monitor when the waves appear.
Must be some effect of magnetic field.
Keep the monitor away from Speakers, UPS, Mobile phones etc...
amolsarode is offline
Old 14-06-2007, 02:45 PM   #4 (permalink)
Post Re: Waves!!
Hi ..
do check out if the cable of the monitor is properly attached
Sumit Kumar is offline
Old 14-06-2007, 04:58 PM   #5 (permalink)
cooldip10's Avatar
Default Re: Waves!!
Tried degaussing a lot of times before but in vain..
Ya the speakers are placed beside the monitor..
Tried moving them.. No.. No.. result..
Do you think its due to any internal interferences??
Old 14-06-2007, 05:02 PM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Waves!!
Do u hav tv tuner card,if yes disconnect the cable for tv tuner and chk
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 15-06-2007, 05:46 PM   #7 (permalink)
cooldip10's Avatar
Default Re: Waves!!
ya I have TV Tuner.. Which cable to disconnect?! The main connection??
Waves like kumarn_2004 QnA (read only) 5 26-02-2007 06:17 PM
Waves like. kumarn_2004 QnA (read only) 1 24-02-2007 10:32 PM
