Old 13-06-2007, 10:48 AM   #1 (permalink)
Default second hand pc for gaming
hulo frnds m planning 2 buy a pc for gaming purpose..m thinking to buy an amd Athlon 64 X2 3800+ and M2V-TVM mobo..is this config enough for gaming and wat graphic card should i use within 5- K which is DX 10 compatible and i was thinking that game purpose is mainly done by graphic card so i can invest more in graphic card and buy a second hand pc like P4 or athlon AM2 and a good graphic card. pls guys help me and my budget is also low...
chinmaythakur is offline
Old 14-06-2007, 12:38 AM   #2 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default Re: second hand pc for gaming
In hardware section you might get some answers
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 14-06-2007, 11:30 AM   #3 (permalink)
I M BACK , WITH A BANG
saggygenius's Avatar
see the processor is good enough for gaming needs , as far as mobo goes go for ASUS M2A VM which is having onboard ATi1250 gfx, which is good enogh for casual gaming which costs 5K,
also a mid range DX10 card will cost you 5500 ,it's 8500GT
saggygenius is offline
best hand held gaming devics akitosforever Reviews 25 21-04-2009 01:48 PM
To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse debasis_7012005 Hardware Q&A 24 10-09-2007 02:37 PM
Does AMD and Linux goes hand in hand? paragkalra Open Source 4 15-06-2006 07:41 PM
Can small gaming companies suceed in todays gaming market Charley Technology News 16 03-03-2005 10:56 PM
