Old 12-06-2007, 04:12 PM   #1 (permalink)
rohus24's Avatar
Default Lcd monitor prob
hi techies!
i own a lcd monitor of some taiwanese make with cmv written on it
now the prob is dat wen i on the monitor
it turns green. bole toh even durin the startup (when that energy star ally etc comes)
now to bring it back 2 normal i hve 2 reset it 2 factory settings
but if i off it and again on it it comes back to its green colour
tried searchin but found notin related 2 lcdon 1 of the threads sum1 told u hver 2 clean the electron gun with spirit but i dont think dat will work with lcd
will i hve 2 buy a new 1 or is it repairable?
btw note dat the monitor comes back 2 normal but ill hve 2 reset it every time i on it....
waitin for ur replys eagerly ..
thnx in advance
Rohit
rohus24 is offline
Old 13-06-2007, 02:15 PM   #2 (permalink)
Default Re: Lcd monitor prob
where r u from?
Place picture of LCD here.
LCD doesn't have electron gun.
try locating a mechanic and gather info abt his reliability...
I ahve seen many such LCDs from korea, they r crap. esp viewing angle..
ashnik is offline
Old 14-06-2007, 09:43 AM   #3 (permalink)
rohus24's Avatar
im frm nerul navi mumbai
also even if i take the screenshot it comes properly without gettin green
rohus24 is offline
Old 15-06-2007, 11:02 AM   #4 (permalink)
rohus24's Avatar
sum1 plz help
rohus24 is offline
Old 16-06-2007, 01:59 PM   #5 (permalink)
i can't promise a proper help from my side, but trying to identify the monitor which might help others in helping u.
I wanted u to put a photograph of the LCD when it is OFF and ON, too.
Not a screenshot..a close on labels would help too.
ashnik is offline
Old 18-06-2007, 10:54 PM   #6 (permalink)
strange problem u have After Restoring also
achha do one thing try to run ur monitor on some other pc
clean ur plugs
kushals is offline
New rig.....HDD Prob parimal Hardware Q&A 1 29-05-2007 11:24 PM
Prob with resolution of monitor cyrux QnA (read only) 1 25-01-2006 06:44 AM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
LAN prob champ_rock Networking 15 05-12-2005 05:56 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
