Old 12-06-2007, 08:50 AM   #1 (permalink)
pushkaraj's Avatar
Unhappy Delayed write failed!!!
I hav 3 hard disks(80 + 40 + 40). On one of the 40gb hd, i hav kept a single partition of 37gb out of which 36gb is occupied(I now regret doing dat ). Of late, whenever i copy any data from that hd to other hds it takes a long time and if i stop the copying process, then i get the error Delayed write failed and the location that it says is G:\$MFT. I checked the size of MFT on that drive thru Diskeeper. It is 421 MB and 2% used.
I really want to save my data but can't figure out how to do dat . Can sum1 help me?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 12-06-2007, 10:03 AM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Delayed write failed!!!
Same thing happened to me last week. copy whatever you need fast, your HDD is giving up like mine did after 5yrs which i used like a pendrive
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 13-06-2007, 03:24 AM   #3 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
my first HD a 20gb seagate lasted only 3 and a half years before dying. second one is nearly 3 years old now.
Btw does a 'tch-tch' noise from the HD during the bios screen at startup mean a HD crash?
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 13-06-2007, 08:50 AM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
Are you using a 40 pin cable instead of the 80 pin for connecting your HD?
See the solutions described here and here
Nokia N86 8MP
Lucky_star is offline
Old 13-06-2007, 10:01 AM   #5 (permalink)
pushkaraj's Avatar
Thanx every1 for ur suggestions. Yesterday was a very hectic day for me. I took backup of my 35gb of data that is 8 dvds in all. Now i hav formatted dat drive and also checked it for errors. Am thinking of putting back data on it and check if it is still misbehaving!!!
OS X Leopard delayed!!! goobimama Technology News 37 17-04-2007 08:11 PM
Sata Hdd-Delay write failed nach p Hardware Q&A 4 06-02-2007 10:25 PM
XP SP3...delayed again. anandk Technology News 20 08-12-2006 03:52 PM
Vista delayed......yet again dIgItaL_BrAt Technology News 15 14-05-2006 05:36 PM
Delayed Start up Vyasram QnA (read only) 15 12-03-2006 07:44 PM
