Old 11-06-2007, 11:16 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
BE FREE
Default My Monitor Turned Red
my monitor is giving red display, iw onder is it dieing its natural death or any other problem from mother board,please help me guys.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 11-06-2007, 11:20 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: My Monitor Turned Red
goto the monitor's settings and reset it to factory defaults. then see
Nokia N86 8MP
Lucky_star is offline
Old 11-06-2007, 11:21 AM   #3 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: My Monitor Turned Red
first do what lucky star has suggested if their isn't any problem with settings then DEGAUSS ur monitor.... if this does not work... then u have to give it for repair
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 11-06-2007, 11:28 AM   #4 (permalink)
Cool G5's Avatar
Also make sure that your graphics card is seated properly into the slot.It also gives a red display,if not properly seated.
Cool G5 is offline
Old 11-06-2007, 12:02 PM   #5 (permalink)
BE FREE
^ its an on board one, I have tried all the possibilities available, I think either to repair or throw it off
Old 11-06-2007, 12:24 PM   #6 (permalink)
"The Gentleman"
vish786's Avatar
only way is repairing now
- Dijkstra
vish786 is offline
Old 11-06-2007, 12:24 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
which brand is it?
Nokia N86 8MP
Old 11-06-2007, 12:27 PM   #8 (permalink)
BE FREE
Originally Posted by Lucky_star
which brand is it?
samsung--samtron 56V 15"
Old 11-06-2007, 12:59 PM   #9 (permalink)
Still Shining!
Lucky_star's Avatar
This turning red,green,yellow,blue is not a new problem to me. Our old BPL TV lost one of its colours every summer. Each year during this time, one of its colours went for a holiday. And we had to replace a part worth 200 bucks.
I came to know that there is a device on the back of the CRT tube which connects to the elctron gun. Its job is to send the high voltage to the gun.
Due to this high voltage, it attracts moisture and gets rusted. And during summers the atmosphere is humid thereby creating a favourable condition to it.
I think this is the problem with you too. If you can open up your monitor, then clean the circuit board on the back of the tube with cotton dipped in spirit. Be cautious to leave the Monitor powered off for about half an hour before opening it. And then check if the problem persists. Or else take it to a repair centre.
Nokia N86 8MP
Old 11-06-2007, 01:26 PM   #10 (permalink)
"The Gentleman"
vish786's Avatar
LOL
- Dijkstra
vish786 is offline
Old 11-06-2007, 02:32 PM   #11 (permalink)
Hmmmm... Dat mus be at least 4-5 yrs old... Anyways I dun think der's any point in servicing...
One of my HP Pavilion 15" monitor bought way back in 2000's still alive n kickin; but I remember a techie'd come to resolder all the joints on the back of the PCb coz once the monitor didn respond...
But pretty old one... Try somethin like dat n check fer blown parts...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 11-06-2007, 02:35 PM   #12 (permalink)
left this forum longback
praka123's Avatar
I got a samtron 56V(successor of 55V), i got this problem of frequent noises in display.i asked one "chip-level" service guy to come and have a look.he "touched" or resoldered some parts of the PCB just behind the CRT.now S/T 56V is not giving me any problem.a problem i face's is how to make this irrepairable <__dont have the courage to do!
praka123 is offline
Old 11-06-2007, 04:51 PM   #13 (permalink)
BE FREE
yes exactly four years old.
Old 11-06-2007, 05:11 PM   #14 (permalink)
Try resolderin...
No not u; ask a h/w personnel to do tat...
jus a luck.... Mite work....
Old 11-06-2007, 09:00 PM   #15 (permalink)
BE FREE
Try resolderin...
dont worry I could do that, any ways I will not try on monitor as zero knowlwdge of electronics, my friend said he will visit tomorrow and open it and see, he was it is a common problem, and most probables it should be solved.
Old 11-06-2007, 09:20 PM   #16 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
most common prob is the cable.. u hav diff wires for diff colors(RGB).. may be the G or B broke internally.. so red all over..!!
it happ to mine.. i fixd it myself.!
ill give u the VGA pin out if i can find it.. it helps changin d cable..
but dnt do it if u dnt hav ne knowledge bout it..
n yea CRT MONITORS WILL HAV FLOWING CURRENT EVN AFTER ITS SWITCHED OFF.. THERE ARE CHANCES OF ELECTRICAL SHOCK...U WILL HAV TO DRAIN D CURRENT(U WUDNT HAV STUFF TO DO THT).. OR ELS LEAVE IT OFF FOR BOUT A COUPLE OF DAYS.
spynic is offline
Old 11-06-2007, 09:52 PM   #17 (permalink)
i am having same problem, but the monitor gives a red tint w/o warning and repairs itself again in some time....i ahve called samsung, they'll send someone 2morrow...
ashnik is offline
Old 12-06-2007, 09:27 PM   #18 (permalink)
BE FREE
thanks for your concern,my friend who is electronic engineer and more 10-12 years of experience is going to check it.
problem found its with the connector cable, temporarily twisted and tied, now display is ok, cable has to be replaced, could some one tell me how much does it cost?
Last edited by azaad_shri75; 12-06-2007 at 09:27 PM. Reason: Automerged Doublepost
Old 13-06-2007, 11:48 AM   #19 (permalink)
kool's Avatar
hey........ my monitor is 4yr old......SAMATRON 56V,
and my younger sis played with magnet2monitor... now it has a light color round patch with red, blue color. so tell me wat should i do now? should i give2mechanic, or will better2buy new monitor???
►► ◄◄ :smile::smile:
kool is offline
Old 13-06-2007, 12:48 PM   #20 (permalink)
Try Degaussing...think it'll work
iammrcool is offline
Old 13-06-2007, 01:31 PM   #21 (permalink)
call samsung, 011-30308282 or ne local no. if u have...
tell them that it is out of warranty, but donm't tell them abt magnet...
hope dis helps
ashnik is offline
Old 13-06-2007, 07:25 PM   #22 (permalink)
BE FREE
yes degaussing should work for magnet problems
Old 16-06-2007, 12:41 PM   #23 (permalink)
Samsumg guys came to my place a2days ago. They just soldered a few dried out points at the back of CRT...that's all
total charge 449/- only...
@shri..
degaussing will remove the magnet effect if the CRT was exposed to a small magnetic feild for shorter time only...
One of my friend had placed his 1000W PMPO spks near the CRT for almost 6 months..we had to call Samsung guys...
peace
ashnik is offline
Old 16-06-2007, 03:54 PM   #24 (permalink)
BE FREE
ok got it, I never knew that someone could do that.
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/60109-my-monitor-turned-red.html
My Monitor Turned Red Hardware Troubleshooting Question This thread Refback 03-11-2010 12:33 PM
I turned my N73 into N73 ME ajayashish Mobiles and Tablets 50 22-02-2007 03:12 PM
the email has just turned 35 ... anandk Random News 4 29-11-2006 11:24 PM
HELP! MY PC HAS TURNED MUTE! mandar5 QnA (read only) 5 20-02-2006 03:14 PM
Dap turned dumb vijaythefool QnA (read only) 5 10-03-2005 06:22 PM
