Old 11-06-2007, 01:26 AM   #1 (permalink)
bizzare_blue's Avatar
Default Problems with DVD-Writer
Two months back, I had to change my DVD-Writer as the older one got dysfunctional. I bought a new Sony DW-G120A writer. When I used this writer to read or write DVD's, it took too long to do so. Then, I got it tested on another machine and it worked perfectly there. Then, I changed the Data-cable but to no avail. Next, I changed my SMPS and got myself a new 400W iBall device. Earlier, I was using a 250W SMPS.
This time again, I am facing the same old problem....The only culprit left is the Motherboard...I want to know if it REALLY is a motherboard problem and will I have to change my motherboard?
Also, I thought I should mention this...off lately, my UPS has been acting very strange and its software sometimes shows "Estimated Battery Time" of around 40-50 minutes....I have an APC Back-UPS ES 500....and earlier it used to show estimated time of around 15 minutes with 100% charged battery....
I wanted to know if this might have to do something with the problem I mentioned earlier. Please...Please....Please help me with this one....waiting for a reply...
Bitten by the open-source bug...
bizzare_blue is offline
Old 11-06-2007, 01:46 AM   #2 (permalink)
CA50's Avatar
Default Re: Problems with DVD-Writer
Try DMA settings, firmware update. Good luck.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 16-06-2007, 01:14 PM   #3 (permalink)
club_pranay's Avatar
try installing the dvd drive on a different channel to your HDD. pls tell if this clicks.
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
CD Writer problems....Strange ones... h_kunte Hardware Q&A 7 05-06-2006 11:42 PM
cd writer problems manishsharma Hardware Q&A 2 29-05-2006 09:53 PM
Cd writer problems LG Samsung ranjan2001 QnA (read only) 10 04-10-2005 07:21 PM
Few problems in my CD-Writer!!!!!! aditya1987 QnA (read only) 5 10-06-2005 06:14 PM
